20 Most Recent
PNY Optima Pro 2GB Secure Digital Memory Card Questions & Answers
How can i delete pictures on card
Click on start. Then choose windows explorer. Then find your memory card
drive letter on the left side of the window pane. Click on the drive
letter. When the memory card drive is selected then go up to the edit
tab in the upper left and choose "'select all". Then hold down the shift
key and hit the delete key on your keyboard. When it pops up asking you
if your sure you want to delete the files click "yes". Just make sure
it's the memory card files you are deleting...
My PNY OPTIMA 8GB MEMORY
take out memory card from camera, and connect memory card to computer using a card reader, then use this
picture recovery software. You can see
http://www.asoftech.com/recover/It tells the steps how to perform camera photo recovery.If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Somehow our pictures got deleted! Is there anyway
Take no more pics until you've recovered your photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos.
This article reviews and outlines several of the better ones:
HEllo... well my
Put the card back into the device then hook the device up to your computer. if that doesnot work then buy a cheap updated USB card reader
Driver de memory sandisk
You don't need driver for it, only you have enabled, "windows update" if the driver is not installed in you O.S. Windows update search automatically the driver and install it or you can try put the memory in a "card reader USB" and this accesorie don't need a driver.
How to delete photos from sd through desk top computer
You will need to connect your PNY Optima to your computer Click start click on my computer to open from there you should see your PNY Optima then right click to select open you should see the data / photo's in there select what you want to delete right click select delete or you can right Click select format this will delete all data on hard disk Hope this helps.
I accidentally deleted my wedding
First of all, do not save any new file to camera's memory card.Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.Download this
picture recovery software from
http://www.asoftech.com/apr/Install and open the photo recovery software, select the memory card, and click 'Start' button.
How to remove photos from card
Click on start. Then choose windows explorer. Then find your memory card drive letter on the left side of the window pane. Click on the drive letter. When the memory card drive is selected then go up to the edit tab in the upper left and choose "'select all". Then hold down the shift key and hit the delete key on your keyboard. When it pops up asking you if your sure you want to delete the files click "yes". Just make sure it's the memory card files you are deleting.
2gb sd card wont read the pictures through usb or computer slot it just shows up with a bunch of squares and letters please help me fix it
click start control panel administrative tools computer management disk management right click on your sd card select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this post a reply
hope this helps you
Card in camera reads "card error". Won't pull
First try cleaning the tiny gold contact points on the card with a small pencil eraser, or a cotton swab with a small amount of rubbing alcohol on it. Next, if the card is still unrecognized, you may need to use recovery software with your PC to recover the pictures. In that case, recommend trying the corrupted card procedures at
this link.
I downloaded photos on computer
Insert the memory card into the
camera to format it if you are receiving error messages such as "Card
Error" or "Card Not Initialized." Press the "Menu/OK" button then press
the left/right directional button to select the "SET" option. Press the
up or down direction button then press "Set Up" and press the "Menu/OK"
to access the setup screen.
Press the down directional button to select "Option 1" and scroll down
to the "Format" option. Press the right directional button to select the
format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does
not work. Rotate the scenery mode dial at the top of the camera to the
"Auto" mode. Press the "Flash" button to enable the flash mode to
provide additional lighting if necessary.Manually set up the Fuji E500 camera with your
computer
if the computer does not automatically detect it. Connect the camera to
the computer using the supplied USB cable and power on the camera.
Click the "Start" button then click on the "Computer" option and select
the FinePix Icon. Choose next on the download wizard to start the
download process.
button to select "Option 1" and scroll down to the "Format" option.
Press the right directional button to select the format option. Press
brighten the lights if the auto focus does not work. Rotate the scenery
mode dial at the top of the camera to the "Auto" mode. Press the "Flash"
button to enable the flash mode to provide additional lighting if
necessary.
Manually set up the Fuji E500 camera with your computer
download process.
Read more:
How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
necessary.
download process.
Read more:
Have brand new PNY OPTIMA SD HC 8gb
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
I have a PNY optima
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I have a PNY optima sd 2gb memory card and it
My Sanyo camera says my sd card it full when it absolutely is not. Ive even tried uploading pictures to my computer and it tells me there is an issue. It just suddenly did this one day and I think I've lost about 150 photos from Easter and other things that I can't get back and worse I can't take any pictures with my camera now.
