20 Most Recent PNY Attach? 16GB USB 2.0 Flash Drive Questions & Answers
My PNY 16 GB Flash drive don't work under 40 degrees
Since you can buy new one for $5 maybe it is time to replace it.
3/11/2018 4:29:54 AM • PNY Attach? 16GB... • Answered on Mar 11, 2018
I just recently used the PNY Attache 16gb flash
Did you change the format from (default)fat32 to Windows file system on your drive?
12/15/2017 7:43:59 PM • PNY Attach? 16GB... • Answered on Dec 15, 2017
Is it ok if my PNY 16GB flash drive is flashing red but working fine?
You should first read the documentation to see exactly what the flashing read light means. It could mean that the drive is near full capacity. Try removing/transferring a few files to your hard drive to see if the flahing read stops. As long as it works ok, I wouldn't be too concerned.
6/25/2014 5:39:34 AM • PNY Attach? 16GB... • Answered on Jun 25, 2014
WHY WONT MY 16GB PNY FLASHDRIVE WORK WHEN I DOWNLOAD A MOVIE ONTO IT?
Perhaps it has not been prepped, eg: not formated to use. Format it with fat32 file system using formatting software from the manufacturer. Also, make sure the movie file does not exceed 16 GB.
6/22/2014 7:34:56 AM • PNY Attach? 16GB... • Answered on Jun 22, 2014
Don't work when it is cold
what is ur flash drive model no, and of which company it is?
5/15/2014 7:10:53 AM • PNY Attach? 16GB... • Answered on May 15, 2014
Not recognized
It showed that the memory card has bad sectors try fixing it by typing "chkdsk x: /f /r" (x is the memory card) then press enter at the command prompt on your computer
12/31/2013 4:26:35 PM • PNY Attach? 16GB... • Answered on Dec 31, 2013
I have a video on my computer that is 4.4G and I
at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.html
12/24/2013 5:51:09 PM • PNY Attach? 16GB... • Answered on Dec 24, 2013
My computer thinks my pny 32GB USB 2.0 flash drive is a disk
All pen and SD cards show up as removable hard drives. Removable or not they can be treated the same. You can format again just by right clicking on it, or use diskmgmt.msc to fully manage via the MS management console.It's basically doing the same as you did from the cmd prompt. If you asking to restore files, then you require a 3rd party software. There is Recuva (free), Wondershare, and Stellar. They all do the same thing.
12/11/2012 10:01:26 PM • PNY Attach? 16GB... • Answered on Dec 11, 2012
I have a 16 gb that does not work right, it registers and then it doesnt register and repeats over and over again. how do i fix this problem?
You have to reformat the flash drive. Right click on the drive properties and click reformat. It will erase everything on it. But fixes most problems with flash drives.
10/19/2012 8:08:27 PM • PNY Attach? 16GB... • Answered on Oct 19, 2012
Drive not recognized by windows
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts hope it helps
8/29/2012 1:53:16 AM • PNY Attach? 16GB... • Answered on Aug 29, 2012
Is the pny 16gb flash drive fat32 formatted?
click start click on my computer you should see your memory card right click then select format another way is to control panel administrive tools computer management disk management right click on your memory card or it might be listed as a mass storage device select format you will see what its formatted in hope this helps
7/20/2012 9:12:34 PM • PNY Attach? 16GB... • Answered on Jul 20, 2012
My PNY 16 GB not being detected by computer
if you are referring to a usb drive
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with post a reply hope it helps
6/26/2012 10:19:28 PM • PNY Attach? 16GB... • Answered on Jun 26, 2012
How do I recover files from a flash drive that has stopped working?
try this link to get an idea of how tough this is
5/19/2012 8:34:50 AM • PNY Attach? 16GB... • Answered on May 19, 2012
The item 'quwof.scr' that this shortcut refers to has been changed or moved, so this shortcut will no longer work properly.What do i do ?
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
3/9/2012 12:41:57 AM • PNY Attach? 16GB... • Answered on Mar 09, 2012
Format a 16gb PNY Micro SD
Format it by using a device like a camera, the computer will not work to format this type of memory. I know this from own experience with 4 different computer in my house..
1/17/2012 2:00:25 AM • PNY Attach? 16GB... • Answered on Jan 17, 2012
What's your problem?My PNY 16Gb sdhc mememry card keeps saying card error in my camera
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
11/26/2011 6:00:48 PM • PNY Attach? 16GB... • Answered on Nov 26, 2011
PNY Attach? 16GB USB 2.0 Flash Drive Logo
Popular Tags
51 questions posted
Top PNY Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • PNY Electronics - Others
Most Popular Question
16g usb flashdrive trying save
  • Electronics - Others
