20 Most Recent
Dynex 19 in. LCD Flat-Panel HDTV Questions & Answers
Gateway FPD1960 TFT LCD Color Computer Monitor suddenly went dead
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
Quart tv model:q210-n
999,000,393. Try these unlock codes. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Unlock codes to some popular TVs are given.
Dead dx-lcd tv-19
Check the solid State Fuse. 15amp 240v..It will be on the power supply or you can call it inverter.
After a power outage my dynex tv stopped
Mine did the same thing. Unplug the basterd and wait about 30 minutes. Unplug all auxilleries connected to it too. Then plug it in again. The red light should come on. The problem is that the liquid crystal power supply got switched off during the outage. If that doesnt work then you have to check the motherboard section 5V. If it is off you should see a number 1. If its on you should see a number 0. Thats what the schematic drawing shows. I found this in the online manual for troubleshooting dynex flat tvs. Fortunately I didnt have to touch the motherboard. I'm not telling you to go inside the tv and get yourself killed. Think safety at all times if you must go inside. Find the manual too. I dont remember where I found it, but you should be able to find one.
Dynex (no database) since power outage
What you have to do it go to the TV Menu and go to channel. Then go to channel scan and do one of those. THe problem is that is just doesnt know where to look for channels, but a quick scan will fix that.
