20 Most Recent
Roxio Easy Media Creator 10 Suite Questions & Answers
I have had Roxio for years but now I cannot capyure or play?
Unless you have changed your operating system recently, it's possibly that a driver or other part of the software has been corrupted. You can try re-installing it with the original disc. It will probably detect the old version and say do you want to repair it or remove it. Try the repair option and follow the on-screen instructions. If that doesn't solve the problem, try a full replace-install.
You can also check that the drivers are up to date for the capture device.
Stoped program runtime
Usually a Run-time event means you have a block of continuous data in a stream. Like a sponge overloaded with water that can not accept additional fluids. This is a coding problem with the software and activity with instruction sets. You may jsut have to start over with the task at hand and see if you can overcome the problem. Try a second time.
Serial number
I'm not sure but check these codes, I hope they could help you:
LB-XVJX4-K5XMW-D265G
XV-P4391-L4SST-F2QVR
4T-PPB4L-H5S88-U457Z
MT-BLW5N-2YDBQ-Y9LPF
36-G85S9-0SJLT-GULM8
My roxio game capture installation
OK here is my fix.If you have any Roxio installed i suggest you uninstall all first.I went to my computer and did a search for roxio.i deleted every thing that said roxio.I then went into regedit and did the same search roxio, i then deleted every registry entry that said roxio.It installed with o problem.i messed with this for days.before i found the fix.Windows 7 ultimate 64 was the operating system on a quad core I7 2.4 ghzA sager note book.
Attempting setup. Get screen that asks for (1)
Is this a corporate edition? If not you should be able to just leave the organization field blank or put 'NA' in there. The serial number should be on the CD / CD sleve or in the documentation. If this is a trial version you may be able to leave the serial number field blank.
