20 Most Recent
SanDisk Ultra II 4GB Memory Stick PRO Duo Memory Card Questions & Answers
Bought a new memory stick. My daughter used her
It sounds like you are using a different level of operating system and the preview feature is not available, or the windows media version is out of date. Also check to see if your version supports the file extension!
How to transfer music from a memory stick t
When you plugin your memory stick on your computer, browse on the folders that the music are saved and then if your eant to transfer it to your computer, right click on it an then copy. Now go to your desktop and then right click then paste. It will tranfer the music file frm the memory stick.
Cannot transfer photo from my SD card to computer
either your pc card reader or adapter for sd card is at fault here....but try this way connect your camera to pc (using usb cable)...go to my computer see the new device (camera) click on it to open ...your pix are there now copy & paste (click & drag) to your folder on the pc...hope this is helpful...feel free to rate
How do I format the card?
K in this case just insert the memory card inside the card reader...........
Connect the card reader to the computer...........
Go to My Computer..........
Right Click On Removable Drive/Disk which is the Memory Card................
Click On Format.............
And now click on start as soon as it is finished just remove it from there and use it........
Good Luck
Recover deleted photos using mac
have you lost your photos on your memory card/USB drive?
If you appear to be a Mac user, just try this Photo Recovery app. It can nimbly recover deleted photo files, music sources and video clips from Mac hard disk drive and memory devices containing USB Drive and SD card.
http://www.leawo.org/photo-recovery-mac/
Simply insert the card to your Mac and run the photo recovery app. The software may help you scan the card and then show you files it has found. Choose the pics you want to get back and hit the "Recover" button to start.
Sandisk ultra write protected
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjijK-2oOeCAxX2k4kEHZN0CnEQrAIoAHoECCQQAQ&url=https%3A%2F%2Fforums.sandisk.com%2Ft%2Fremove-write-protection-from-usb-drive%2F33510&usg=AOvVaw3A01NeRgbLmAWvj17rGaBA&opi=89978449
11/28/2023 5:48:51 PM •
SanDisk...
Answered
on Nov 28, 2023
