20 Most Recent 1999 Chevrolet Silverado 1500 Questions & Answers
Ctsy fuse when put in makes a clicking under dash as if a short? truck 1998 chevy silverado no lights truck wont start?
What lights ? And won't start how ? The clicking is more then likely a relay or a module of some sort . When you turn the key to the start position does the start engage an spin the motor ? Or nothing happens , a crank no start or no crank no start !
2/27/2024 9:48:04 PM • 1999 Chevrolet... • Answered on Feb 27, 2024
3answers
The service 4wd light came up on my 04 Z71 a
is it electric shift? if ya it mite be the shifter motor. if no it can or mite be vacume lines.
12/23/2023 2:04:52 AM • 1999 Chevrolet... • Answered on Dec 23, 2023
Cannot find switched 12v wire on factory harness on 1999 Chevy Silverado, it says it's yellow on the diagram but there is only one yellow wire in the harness and it goes to the rear speaker?
You should have two Yellows 1999 Chevrolet Silverado Stereo Wiring Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Right Window Trim Front Speakers 6 1/2" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 4" x 6" Side Pillar Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue https://www.google.com/search?q=1999+chevy+silverado+stereo+wiring+diagram+color+code
1999 Chevrolet Silverado Car Stereo Wire Colors and Locations
the12volt.com https://www.the12volt.com > installbay > stereodetail 1999 Chevrolet Silverado Stereo Wiring ; Left Front (+), Tan ; Left Front (-), Gray ; Right Front (+), Light Green ; Right Front (-), Dark Green.
12/1/2023 12:46:21 AM • 1999 Chevrolet... • Answered on Dec 01, 2023
4answers
Are the head lights on all the time 1999 chevy silverado 1500 4x4
In the 1999 Chevy Silverado 1500, the headlights are not designed to be on all the time by default. They are typically controlled manually by the driver using the headlight switch, although some vehicles may have a daytime running lights (DRL) feature. If the headlights are continuously on, it could be due to a modification or wiring issue, and it's recommended to consult the vehicle's manual and seek professional assistance if needed.
10/21/2023 7:08:41 AM • 1999 Chevrolet... • Answered on Oct 21, 2023
2answers
1999 Chevy Silverado. How to adjust the shift cable please?
Question edited for clarity. Question moved to model category. Video here https://www.google.com/search?q=1999+Chevy+Silverado.+How+to+adjust+the+shift+cable ..
10/20/2023 6:48:04 AM • 1999 Chevrolet... • Answered on Oct 20, 2023
I have a 1999 Chevy Silverado 4l60e transmission, every gear is neutral.
First make sure the fluid is full. If it is then you have internal problems. Possibly the linkage or oil pressure .
10/19/2023 5:43:17 PM • 1999 Chevrolet... • Answered on Oct 19, 2023
2answers
1999 Chevrolet Silverado Z71 4x4. What causes no indicator lamps light up on dash when I first turn key to start truck?
By indicator lamps ,you mean warning lamps (check engine,oil,battery, air bag,etc ?
4/9/2023 1:47:59 AM • 1999 Chevrolet... • Answered on Apr 09, 2023
2answers
Have 99 chevy silverado 1500 I have a headlight problem all the other lights work but headlights won't turn on
-Check "headLight fuse"-Check connector at the headlight.-Check the bulb. (It could burn out)Mai
1/2/2023 3:43:15 AM • 1999 Chevrolet... • Answered on Jan 02, 2023
3answers
I started my 1999 chevy silverado 5.3 liter this
sounds like you have a coolant leak, if coolant is low it will cause both of your symtoms as to where it is coming from, there are many places but common ones are hoses/clamps, water pump or radiator.
11/1/2022 11:56:23 PM • 1999 Chevrolet... • Answered on Nov 01, 2022
2answers
I have a 1999 chevy silverado and the security light comes on and stays on. After awhile, the light begins to flassh and the truck will not start till I reset the security system. how do I fix this?
you need to turn ignition on and leave key in on position for ten minutes then turn key off then back on again for another ten minutes then one more time for a total of three times or 30 minutes and the system should relearn the key. System is called passlock. I can email you the procedure form alldata if you want.
10/17/2022 8:27:43 PM • 1999 Chevrolet... • Answered on Oct 17, 2022
If gauges dont come on, the truck wont start.
Sounds like a bad ignition switch.
9/27/2022 12:13:55 PM • 1999 Chevrolet... • Answered on Sep 27, 2022
What is the box that sits in front of my gas tank
It is likely the charcoal canister for the fuel tank vapors, and all part of EPA regs.
6/23/2022 4:17:53 PM • 1999 Chevrolet... • Answered on Jun 23, 2022
4answers
5.3 L Missing and Rough Idle Intermittently
i have a 2001 chevy z-71 5.3L. I keep getting a random/multiple misfire code for cylinder 1 . I have replaced plugs, wires, coil pack(only on #1 cylinder)., and fuel pump. I still keep getting the cylinder 1 misfire code. I put truck on a scanner and watched the cylinders. # 1 misfires at idle but quickly stops misfiring at around 1000 rpms. you can here the engine miss at idle but truck runs great on road . anyone else ever had this problem?
6/14/2022 7:37:40 PM • 1999 Chevrolet... • Answered on Jun 14, 2022
3answers
Vibration in the steering wheel on a 4wd truck
I just had the same issue with a 1999 2500HD and the vibration got worse above 50 mph. Problem was resolved with a new driveshaft. Old one (aluminum) was badly out of true and the problem didn't really occur until I had the U joints changed - then bent driveshaft vibration was noticeable. New driveshaft resolved issue.
6/10/2022 3:18:04 AM • 1999 Chevrolet... • Answered on Jun 10, 2022
96 chevy 4x4. no ind lights. stuck in 4hi
Replace the selector switch assembly. Common failures.
3/18/2022 10:26:25 AM • 1999 Chevrolet... • Answered on Mar 18, 2022
2answers
I took out the front
are there splines on both ends ? .... the splines will go toward the transmission.
Robert
12/28/2021 8:33:00 AM • 1999 Chevrolet... • Answered on Dec 28, 2021
A/c and heat dash vents won't work but all others are fine
check the actuator motor on the heater sounds like the motor is not directing the air as it should. The motor is in the center of the truck inside attached to the heater and has arms on it to move the heater and ac doors.
11/23/2021 11:18:39 PM • 1999 Chevrolet... • Answered on Nov 23, 2021
2answers
MAF sensor and injectors
the mass air flow sensor is located between the air filter housing and the air inlet to the intake manifold, remove the two band clamps holding the maf sensor, clean when cold with CRC mass air flow sensor,remember to take off the three wire plug to the maf sensor,get back to me if you need more help,please rate my fix as i strive to be the best,problems,get back to me
9/26/2021 5:23:08 AM • 1999 Chevrolet... • Answered on Sep 26, 2021
Have a 1999 chev silverado
Just a hunch, is the SECURITY light illuminated somewhere on the dash when it wont start? If so, you have the anti theft shutting down your fuel injectors. Heres a link with info and solutions if this ends up being your problem. http://vatspasslockpasskeysecurityhelp.yolasite.com/
8/31/2021 9:37:41 AM • 1999 Chevrolet... • Answered on Aug 31, 2021
I Have a 97 Firebird the tension pulley broke the car ran hot up to about 220 I replace the pulley now the car won't start could it be the crankshaft sensor
If it ran before then check your work, a wire may be off from somewhere.
8/15/2021 9:57:35 AM • 1999 Chevrolet... • Answered on Aug 15, 2021
1999 Chevrolet Silverado 1500 Logo
6,290 questions posted
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
View Most Popular
Silverado 1500 Chevrolet
  • Silverado 1500 Chevrolet
Most Popular Question
head lights all time 1999 chevy
  • Cars & Trucks
