20 Most Recent Mitsubishi Cooling Fan Set for WD-62530 Questions & Answers
I replaced the lamp on 62530 worked fine for a few days, now the picture won't come on and the lamp light does come on.
unplug the unit wait 30-60 seconds & plug back in. Try unplugging your source at TV input & then plug it back in
1/3/2015 4:58:53 AM • Mitsubishi... • Answered on Jan 03, 2015
2answers
My tv blinks 6x red and 1x yellow. whats that mean?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://homenol.blogspot.com/ https://electronicshelponline.blogspot.com/ If blinks continue without any pause, or the LED light stationery; the main board is faulty. Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview/
1/9/2023 7:23:43 AM • Mitsubishi WD... • Answered on Jan 09, 2023
0answers
How to replace the main board on a mitsubishi WD-60C8
Basing the replacement of the board on the clicking sound of a relay trying to close is not a safe bet. The first thing you need to do is check the bulb. Then there is a ballast board and then the Power supply board. Parts might be hard to find. Use the website I listed to see what part numbers are then google it or look on eba or amazon for those parts. Mitsubishi WD 60C8 TV Parts
1/18/2018 11:51:33 PM • Mitsubishi WD... • Answered on Jan 18, 2018
My mitsubishi tv started out with white dots on the screen.eventullay i heard a sizzle and pop and the tv went out. so i did research found that i needed to replace the dlp chip which i did and the la
Most likely a fuse blew when the lamp blew, there is internal fuses on the power supply board on these mitsubishi's, if the fuse is ok though then most likely another component somewhere failed.
1/2/2018 10:55:36 AM • Mitsubishi WD... • Answered on Jan 02, 2018
Hi guys i have a Mitsubishi WD-65C9 DLP that gives me nothing but a few seconds of audio before shutting off with a blinking red light. ERROR 61
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
3/27/2017 4:27:30 PM • Mitsubishi WD... • Answered on Mar 27, 2017
How do I fix a mitsubishi tv that shuts off and has a steasy red light
Replace your lamp. Make sure its a real Osram bulb and not some cheap knock off. These folks have Osram bulbs and a 6mo warranty. Projector Lamps and TV Lampson Sale ProjectorLamps com stocks Superior...
9/30/2016 8:04:57 PM • Mitsubishi WD... • Answered on Sep 30, 2016
What is the correct part# for a DLP: Mitsubishi WD60737 60", Serial#139599 Made June 2009?
If your set worked well (no lines, maybe only white or black scattered pixels) before you replaced the DLP chip, then your problem could be that the DLP chip did not get seated properly or the cam screws were not tightened enough after replacing the chip. The DLP chip must be seated properly in its socket or else line and column lines will be seen. There is also the possibility that the DLP chip is defective or suffered static damage while being handled during the installation. Hope this helps.
8/31/2016 8:45:35 PM • Mitsubishi WD... • Answered on Aug 31, 2016
How do I get rid of smudges on WD73642 screen.seems to be right in the glass
Hello. There are three places smudges that are seen in the picture can be found on a projection TV, the lens, the screen, and most likely, the mirror, but none can be discounted. All three can be accessed by removing the bezel and screen assembly. Most of the screws are around the edges from the back, and some are under the flap that hides the front controls. Good luck!
8/10/2016 1:18:31 AM • Mitsubishi WD... • Answered on Aug 10, 2016
I replaced a dlp chip in a mitsubishi tv. i now have a band 4" high with vertical bars in it, running across the screen. what is wrong?
Hello. I have replaced many DLP chips, as I work for a repair shop. I have seen similar symptoms when the chip isn't seated properly in the mount. There is a gray screw that should be loosened to remove the chip, and tightened when the new one is installed. Most importantly, you must make sure that the chip is seated flat in the socket before tightening the gray screw. Since you have done it once, you should have no problem correcting the issue! ??
8/9/2016 11:22:16 PM • Mitsubishi WD... • Answered on Aug 09, 2016
Mitsubishi tv WD-73640 wont turn on. 4 red light then 8 yellow lights
Hi, if you power your TV on and see a black or grey screen, it may be on the incorrect input. Inputs get changed when switching the TV input for dvds or video game consoles. Look for a Source or TV Video button on your TV remote, not the cable remote. Before doing this, please make sure all connections are secure. I hope this helps or reply with more questions. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
7/30/2016 5:27:59 AM • Mitsubishi WD... • Answered on Jul 30, 2016
Mitsubishi Cooling Fan Set for WD-62530 Logo
1 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
replaced lamp 62530 worked fine few
  • Televison & Video
