20 Most Recent
2000 Daewoo Lanos Questions & Answers
HOW WE CHANGE TIMMING BELT IN LANOS CARS
mcdevito75 here, that is a shop job only, special tools may be needed to do this job. Best bet let your local repair shop do this job, It"s going to cost you more in time and effort to change the timeing belt than at the shop.
Netural safety switch
Daewoo cars have track record for dependability in addition to solid construction. The most important part of a car's design is the safety features. Circumvent excessive risk while motoring by insuring that your car has the safety gear that you want.
A vehicle's Neutral Safety Switch is located on your clutch in the case that it's a manual transmission, and on the shifter in an automatic. A broken Neutral Safety Switch can cause your vehicle to suddenly start in gear, causing vehicle damage or personal injury. If you don't have the Neutral Safety Switch, your vehicle will fail to work. The Neutral Safety Switch is typically situated below the clutch of trucks which have a stick-shift transmission. The primary function of a Neutral Safety Switch is to stop your truck from starting when in gear. The car's Neutral Safety Switch acts as a safety feature, keeping you from starting the engine if the car is in gear. The Neutral Safety Switch is an electronic part which is essential while starting your car.Here's a
link to what it look's like.
Lost of power, exhaust pipe turning cherry red.
7 - TP Sensor (Throttle Position)
This is the problem with my vehicle i have a Honda cat turned cherry red smoked the color was white and i looked at the ecu for the flash codes i got 7 witch is stated above replacing that sensor should help the problem. I am doing the same thing tomorrow going to buy the part install it and hope it fixes everything if not i will come back and let you know. everything above you say i am having the same issues so its not just you :)
Daewoo problems
HI
is the service engine light com on when you turn the switch on ??
if no . check fuses ??
if yes . check the CKP crankshaft position sensor ??
give us more details to can help you pleas !!!
with my best wishes
This car is unsolve able ???????
Hi, This Might have nothing to do with your problem, but you have nothing to loose by the sounds of it, the breather pipe from the bottom of the sump (behind the starter motor) to the top of the rocker box, mine was clogged up with slug like greese causing sencer problems and giving false information to the computer. (running rought) you got nothink to loose, try it.
Chris
