20 Most Recent Celestron AstroMaster 114 AZ (50 x 114mm) Telescope Questions & Answers
A 10 mm. If you know the focal length of your scope, divide that by the focal length of the eyepiece, and the answer is the magnification you will get. However bear in mind when viewing astro objects, a very high magnification will degrade the image sharpness, and make the object hard to get on centre. Most experienced amateur astronomers use a medium power eyepiece at most.
Celestron... | Answered on Apr 10, 2014
Your DEC is the same as your Latitude--
Right Ascension does not matter for now. Polar Align the scope on the star Polaris-- read this:
http://arnholm.org/astro/polar_alignment/index.html
Once you are polar aligned, rotate the tube to a star in the sky that you KNOW the name of. Look up the Right Ascension of that star on a cell phone app or a laptop planetarium program like this one:
www.stellarium.org
Rotate the RA setting circle so it matches what the phone or laptop indicate. LOCK down the RA circle. Your scope is now adjusted to the sky and you can use the numbers on the DEC and RA to find other objects of known RA & DEC.
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Celestron... | Answered on Sep 17, 2011
No glasses would not matter. Practice focusing on a distant object during the day time. Locate a local Astronomy club, the members will help you.
Celestron... | Answered on Mar 21, 2011
Did you put an eyepiece into the focuser? You are NOT in focus -- practice focusing during the day time on a distant object. TURN the focusing knob to either the left or the right until you get a sharp image.
Celestron... | Answered on Jan 19, 2011
It depend on the eyepiece anywhere from 10-20mm away.
Put the eyepiece with the largest number written on it into the focuser. DO NOT use the 2x barlow -- practice focusing on a distant object during the day time.
Celestron... | Answered on Jan 01, 2011
RA moves the polar axis--- and DEC moves the scope from side to side.
There are two knobs that turn these two axis.
See this:
http://www.themcdonalds.net/richard/index.php?title=Polar_Alignment_of_your_Equatorial_Mount
Celestron... | Answered on Dec 30, 2010
Put the eyepiece with the LARGEST number written on it into the scope. DO NOT use the 2 x barlow if you have one.
The end with the focuser is the UP end of the tube -- the mirror is on the bottom of the tube.
Celestron... | Answered on Dec 27, 2010
You will need to provide more detail for us to solve this problem. Are you talking about Altitude and Azimuth adjustments??
Celestron... | Answered on Dec 10, 2010
Hi, this is a real handy scope. You need to remove the disk like cover for the high polished mirror located at the but end of the scope. Then insert one of the two ocular lenses provided into the viewing aperture. Next, aim the polished mirror end at something obvious like a street light. Use the range finder located opposite the viewing aperture, (switch red button on) and align the circles with the red dot. Happy viewing!
Celestron... | Answered on Nov 16, 2010
The red dot finder is NOT lined up with the main tube. During the daytime locate a distant object with the main tube eyepiece. Without moving the telescope adjust the red dot to point at the exact same spot.
Celestron... | Answered on Jul 08, 2010
You posted this in the telescope forum.
Celestron... | Answered on Jun 07, 2010
collimate your mirror.
sky and telescope shows you how to do it.
it's under 'Do-It-Yourself' section.
hope this helps :D
Celestron... | Answered on Aug 27, 2009
Most telescopes do not have a zoom-- they have different numbered eyepieces that give different magnification-- you can buy a zoom eyepiece however.
From what you describe -- put the eyepiece with the LARGEST number written on it into the telescope-- this is the LOWEST magnification. Now focus on the moon and or a distant land object during the day-- once it's in focus -- nice and sharp-- replace the eyepiece with the next LOWER number-- for more magnification. AND-- refocus the telescope for that eyepiece.
Celestron... | Answered on May 20, 2009
Why not look at the old battery, or look in the manual ?
Celestron Optics | Answered on Nov 28, 2019
It is impossible to assess the weight (or more correctly Mass of a star, as weight is a perceived function of Earth's gravity) without knowing the chemical make up of the star. That is why astronomers use the star's measured albedo to qualify and quantify them.
Celestron Optics | Answered on Sep 16, 2019
Read the manual. Follow the instructions therein.
Celestron Optics | Answered on Jun 13, 2019
Celestron AstroMaster 114 AZ (50 x 114mm) Telescope Logo
Popular Tags
16 questions posted
Top Celestron Optics Experts
Ekse
Bob Peloquin
Level 1 Expert
Vernon Taylor
Are you a Celestron Optic Expert? Answer questions, earn points and help others
View Most Popular
Celestron Optics
  • Celestron Optics
Most Popular Question
joe name also joe just bought
  • Optics
