20 Most Recent
Andis AGC2 Hair Trimmer Questions & Answers
****** of hinge assembly stuck
If the latch has been pushed down without a blade on it you will need to get a flat head screw driver. Push up the blade lock and put the screwdriver behind the the tongue on the hinge. While pushing up on the latch push the tongue out with the screw driver. If you need any add'l assistance please call the Andis customer service dept at 1-800-558-9441.
My andes agc2 doesnt run. i opened it and noticed
This round cylinder is a permenant magnet and doesn't actually connect to anything, the only contact which matter are the copper wires connecting the circuit board to the Carbon brushes.
This may be as simple as a faulty cable check for power to the circuit board.
Clippers stopped clipping. I changed
Sound as though the blade drive needs replacing, commonly you will notice tram lines in the cut on your longer blades or the shorter blades struggling to cut
Replace drive bearing
Drive bearings can only be replaced (safely) by removing the motor and then the armature.
