20 Most Recent
Astoria Argenta SAE/JUN Espresso Machine Questions & Answers
Leaking from unerneath
YOU HAVE TO OPEN THE TOP TO SEE WHERE THE LEAK COME FROM, OVERPRESSURE VALVE, CONNECTIONS TO BOILER , O-RINGS, SEALS, SENSORS CONNECTED TO THE BOILER ETC. U CANNOT TELL FROM THE BOTTOM!!
RUDY.KY
Looking 2 reinstate the electronic missing parts so it sautomatic
Yes the autofill is inside the control electronic box . If you know about electronic PCB board you migh need to replace a relay which is welded on the PCB board. Or you have toreplace the whole electronic contraol box which is expensive.
Please remember to vote for a rating for this answer, thanks
I have an Astoria Argenta SAE1 Jun espresso
Your problem could be one or two items (element or pressure stat or both). Remove the screw in the top of the P.stat(black or gray rectangle box with electrical wire going in from bottom about 4-6 inches long), lift the cover and check the terminals(turn power off). Make sure that there are no loose connections on the terminals.
On the element remove the wires that are connected to it and test with an Ohmsmeter.
Cannot turn off flashing lights on buttons to start espresso
The keypad needs to be programed. Depending on your model there will be a small toggle switch on the right side, just behind the connection of the hot water valve(you will have to remove the top panel). Move the switch to the left, then press the program button at which time all the lights will be lit. Using a measuring cup press a button you want to program until you get the desired amount, then press the stop button(when programed the light will turn off), repeat to program the other 3 buttons. When done program move the toggle switch to the right. If the machine does not hold the program then the flowmeter under the drain tray(silver box with 3 wires on top), is damaged. Either repalce the top or check the impeller in the flowmeter, the magnets might dirty.(Make sure water is turned off before openning the flowmeter.
Will not dispense water
If you're pump is working and your needle shows around 9 bars when running, most likely your
Solenoid valve is bad. This can be caused from improper backflushing among other things.
We stock them ($60). Email me at
[email protected] with your contact information or from our website
www.kaldi.com
Alex
Jus got an astoria sae junior i got hot water steam but no water on brew head no boiler pressure is 0 all the time just change the pump need help
There could be a number of issues here. If the pump pressure reads 0 then that would suggest there is no power going to the pump. Does the machine hum when you press for a brew? If it does then the pump is receiving power.
If you have changed the pump recently have you reset the pump pressure manually on the pump head? This is done by adjusting the nut (12mm I think?) anti-clockwise to increase the pressure. Clockwise to reduce it.
Perhaps the pressure gauge is faulty?
No water to the brew head if the water pressure is fine and the pump is working indicates a blockage in the group head. You will need to strip down the valve and clear the filter which is a small hole under the large nut...
Make sure the water is turned off and the machine is cold and isolated before stripping out the valve.
