20 Most Recent
Trend Micro Internet Security Pro 2008 Full Version for PC (733199435925) Questions & Answers
Download to another computer
on the other computer find and down load that system
when installed it will ask for the code
enter that code and it will finish installing
copy the code to a piece of paper as it can be case sensitive so you do not make a mistake
what I do is to open up word and copy it there , then required I copy past it in the code box
Is there any possibilty to reset the password
Hi there and welcome here,
Yes there is possibilities to reset the password, you can get a cd that can reset the Admin password and others accounts. That is the normal metod, you are lucky that it has reset and not make a new password :Oo, there are some that do that and after ask for money :OS.
Trend Micro should be a reliable Internet security and if you scan your machine once in a while there shold be no problem.
Additional info :
I have hear about that someone has made a password but after a time the password was reset by himself, here I do not know why, but I have done that to a computer and the next time I should help the person I did notice that the password was reset ted ??
Will not connect to the internet
Remove remnants of the old version:
http://esupport.trendmicro.com/Pages/How-do-I-remove-old-or-new-versions-of-Trend-Micro-products-in-my-comp.aspx
After removing the remnants install the latest version of your program:
http://esupport.trendmicro.com/Pages/How-to-download-and-install-Trend-Micro-Internet-Security-Pro-2010.aspx
When I reinstalled SwiftKit a Trend Micro alert
You need to go to "Prevent Unauthorized Changes" then under that there will be an "exceptions list" option. From there you will be able to unblock all the things you accidentally blocked.
My antivirus protection is not working
Well What I Understan Of Your Problem On The Basis Of That I Would Recommnd That Uninstall Trend <icro From Your System Using A Good Uninstaller Software. Then Clean All The Temp, Prefetch Files And Browsing History. Restart Your System And Then Install The Fresh Copy Of Trend Micro. Here's The Link For Uninstaller Software......> http://www.wugnet.com/shareware/spow.asp?ID=524<---------- Do Make Sure You Use The "" ADVANCED "" Mode To Remove The Trend Micro From Your system...
New update needs my help to solve a problem
one of enhancements of the latest version is lesser alerts / pop-ups from the program (which you can customize to taste).
as long as you perform regular updates (what's actually updated is the pattern files for malwares & scanning engines - all versions use the same) and regular full-system scans, you're fine.
I forgot my key number and password. How can I retrieve them
Best bet would be to ask assistance from someone with credentials to reset your user account. Otherwise you may try to completely default the device with directions included with unit. This may involve any software that came with it when new.
