20 Most Recent
Eastern Tools & Equipment ETQ IN1800I 1,800 Watt 3.4 HP 4-Stroke OHV Portable Digital Inverter Questions & Answers
Etq in1800i will not start
Did you just clean the Bowl in the Carburetor or did you make sure the tiny holes in the Jet was clean too? Not familiar with this model but I doubt it is anything more than Gravity fed.
Can,t get carb off to clean ETQIN1800i
There are two plastic nipples that are pressed into rubber grommets, just grab the bottom and pull straight out while wiggling the air box assembly. Make sure you pull the rubber fuel lines out of the way so that the air box cam come straight out. The resistance you are feeling is either the rubber grommets or the fuel lines in the way. I have had mine apart a dozen times!
Owners manual
no, you just have to dig into it further to find your issue. sorry but these generators I don't see very often. Like I've worked on 5 in the last 6 years yet they aren't all the same
