20 Most Recent
Kicker CVR12 Car Subwoofer Questions & Answers
How to hook up from post to post
if u have two pos. and two neg. on the back just run a wire from one pos to the other pos and do the same with the neg just run the wire from the box to one of the pos and neg only on one side u have two wires runing to them
Comp12
1.75 cubic feet to 3.25 cubic feet or go to the kicker website and get some ideas on box building. Pick a style. Have fun
How to wire kenwood amp to kicker cvr 12"
How you wire it depends on how hard you want drive your amp. If your woofer runs 4ohm per coil I would wile it in series (amp +to sub +1 sub -1to sub +2 amp - to sub -2) then run it for a week and see if it has enough power. the lower your Impedance (the resistance load on the amp) the harder your amp works and more THD (noise) is produced. (Dclass amps aren't know for being clean to begin with) configured like this your amp will see 8ohms and sound the clean east. if this turns out to be not enough power wire it in parallel and double the output. wire amp + to sub +1 and +2 then amp - to sub -1 and -2.
A word to the wise... start with your volume very low and work up slowly most speakers will puk up the voice coil before the amp starts to get warmed up. you would hate to have to buy a new sub.
Have fun
Rob
My (2) 12 in kicker
turn down the gain and the preout in the head if it supports it. also turn down the frequencey to 80. also dont over shoot the speaker by turrning up the bass on the head unit and then turning up the volume.
My bass isn't clear anymore. it sounds cheap and
Distortion of sound is commonly caused by a leaky electrolytic filter capacitor.
Your unit need to send to repair shop because it is quite technical diagnosing the faulty capacitor.
Also dry joints are going to consider because it will produced the same problem as what you encountered right now.
This is fixable anyway.
Thanks for using fixya.
Pls rate my help.
