20 Most Recent
Apple iPhone (16 GB) Smartphone Questions & Answers
Iphone rightone maker software
If you have a song in mind and you want to make a rington out of it then I think you can use itunes to do that. The music file should be an Apple purchased song though...
I need to transfer some photos and videos from my
First you need to authorize your PC with your iTunes account with iTunes if you haven't already done so. With your iPhone connected to iTunes and without syncing, at the iTunes menu bar go to File and select Transfer Purchases From - the name of your iPhone.<br>
Besides what mentioned above, I like to share you a article about transferring files from iPhone to computer, which included transferring iPhone photos and videos to computer/iTunes.<br>
Hopefully this works for all of you like it just worked for me!
How do i set my music as a ringtone on iphone 4
It's a very tricky method. Follow these step precisely, and you should have your own custom ringtone like I have.
Please rate this solution if it helps you.
1 Open iTunes.
2 Find the song that you want to make into a ringtone.
3 Listen to the song and find the part of it you want to use. The chorus may be a good place to start.
4 Write down the start and stop times of the clip.
5 Right-click the song and select "Get Info."
6 Click the "Options" tab.
7 Type in the start time of your ringtone in the text box next to "Start Time" in the minutes:seconds (i.e., x:xx) format.
8 Type in the end time of your ringtone in the text box next to "Stop Time." Make sure the ringtone is no more than 40 seconds long.
9 Click "OK."
10 Right-click your song again and select "Convert Selection to AAC." Wait for iTunes to convert your song. It will create a duplicate version.
11 Right-click the ringtone and select "Delete."
12 Click on the "Keep Files" button.
13 Find the file. It's usually in your User folder under "Music > iTunes > iTunes Music" and under the band's name. It will have an extension of m4a.
14 Replace the m4a extension of your ringtone with m4r. You can either double-click slowly to rename your file, or right-click and select "Get Info" on a Mac or "Rename" on a Windows PC.
15 Click "Use .m4r" or the PC equivalent when the system warns you that the change may affect the use of your file.
16 Double-click the ringtone file. ITunes will automatically add it to your ringtones folder in your iTunes Music Library.
17 Connect your iPhone and sync your ringtones.
Itunes error 3259
salam,dear, Resolution
- Remove any proxy information you have set up.
- Update to the latest iTunes software version.
- Try turning off your Firewall to see if the issue is resolved (this includes the built-in Firewall or a third-party Firewall such as Norton Personal Firewall, McAfee, Symantec, etc.). Learn how to turn off your Firewall:
Also check me
Internet plans
For T-Mobile plans are:
$9.99 for Edge internet
$24.99 for 3G internet
How to access the battery
iPhone has an internal rechargeable battery. The iPhone battery isn't user replaceable; it can
only be replaced by an authorized service provider. For more information, go to
www.apple.com/support/iphone/service/battery.
I tried charging my iPhone, but it wouldn't
It's gonna be better to replace your USB cable becuse that's gonna be a bigger problem when the sync fails or worse, when the software update fails. That could turn your iPhone useless.
My iphone will not charge, I have tried the power
I had found a guide that fixed many Iphones, and have put every step of their repairs into these guides. These step by step guide will have you using your favourite App. in no time at all.
The iPhone Repair Guides has illustrated photos of an Iphone repair. Follow along and confirm your work with the pictures in the books . Iphone repairs has never been so easy.
Because I have repaired many Iphones using the techniques found in these Repair Guides, this eBook will show guaranteed methods of fixing your Iphone. These methods have been used successfully numerous times by regular people just like you.
Why send your Iphone out to be fixed and pay $150 dollars or more when you can download this eBook right now and have it working again?
Purchase iPhone D.I.Y. Repair Guide Now !
You many just want to change the casing or front face because of scratches , your Iphone falls and the screen cracks, or the wifi stop working . Many different problems are resloved in these guides .
Iphone all puk codes are not working
HiPUK code is called as PERSONNAL UNBLOCKING KEY.Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK codeDONOT enter the PUK code several times wrongly,It will block your sim card permanently.This PUK code is FREE. You no need to pay any sum to get the PUK codeThank You.
