20 Most Recent Dewalt DC742KA Cordless 12-Volt 3/8-Inch Compact Drill/Driver Questions & Answers
Where can I download an owners manual for dewalt dc742ka?
http://powertoolshelp.com/dewalt-dc742ka-cordless-hammer-drill-users-manual
2/12/2015 10:40:16 PM • Dewalt DC742KA... • Answered on Feb 12, 2015
I have a Dewalt D55166 air compressor that doesn't work when I pull up the button. Where do you suggest I start to troubleshoot this issue? It worked just fine a week ago.
https://support.dewalt.com/hc/en-us/articles/360017799818-Why-won-t-my-compressor-power-on-
1/6/2024 10:40:37 PM • Dewalt Air Tools... • Answered on Jan 06, 2024
Does a Dewalt D55166 air compressor have a reset button?..
It has a pressure valve, that's all.
1/6/2024 12:48:32 PM • Dewalt Air Tools... • Answered on Jan 06, 2024
2answers
Dewalt D55146 air compressor almost immediately shuts down
I was facing this exact same issue. My dewalt compressor was spitting milky oil, and then suddenly stopped working but then I found this troubleshooting guide which really solved my issue: https://aircompressorinsider.com/air-compressor-problems-and-solutions/ Your mentioned issues were at somewhere around number 60-65, I dont exactly remember it now :)
7/21/2023 10:20:01 AM • Dewalt Air Tools... • Answered on Jul 21, 2023
My Dewalt 15 gal D55168 air compressor will not continuously build air after air supply has been depleted. Please provide help or a service center close by. I live in NW Oklahoma. Thank you.
you may be using more air that unit can supply. This is a very common error. it is only 5 cfm which is small. Call Whitton Supply Co. or visit our local Oklahoma City showroom (405) 236-5561.
5/12/2023 6:22:12 PM • Dewalt Air Tools... • Answered on May 12, 2023
Where is the reset button on a dewalt 20v air compressor?
there is not one.
2/8/2022 4:39:43 PM • Dewalt Air Tools... • Answered on Feb 08, 2022
My dewalt 15 gal D55168 runs momentarily then trips the GFI outlet.
There is a ground fault in that case. If you are in need to ask this sort of question, I recommend the services of a qualified electrician.
8/26/2021 12:51:48 PM • Dewalt Air Tools... • Answered on Aug 26, 2021
Where is the reset button on a Dewalt D55146 air compressor?
THERE IS NONE
3/26/2021 7:15:06 PM • Dewalt Air Tools... • Answered on Mar 26, 2021
I need to find the reset button on a D55146 Dewalt air compressor
There is no reset button for the compressor, if the compressor won't start check the valve is not open, also check the outlet power, Shut the drain valve at the bottom of the tank if it's open
3/26/2021 6:56:39 PM • Dewalt Air Tools... • Answered on Mar 26, 2021
Dewalt D55168 225 PSI Air compressor: What are the preset pressure limits for this model? Is it actually 225 - 180?
https://www.manualslib.com/manual/494085/Dewalt-D55168.htmlSpecifncationsMODEL D55168WEIGHT 88 Ibs. (39.92 kg)HEIGHT 41.75" (1060.5mm)WIDTH 19.0" (4826 mm)LENGTH 21.25 (539.8 ram)AIRTANK CAPACITY (GALLONS) 15 Gallon (56.8 fiters)APPROX CUT-_N PRESSURE 160 PSI (1103.2 kPa)APPROX. CUT-OUT PRESSURE 200 PSI (1379.0 kPa)SCFM @ 90 PSI (620.5 kPa_ 5._cant get fixya comment to work so will edit here...The 200/160 are the typical DS55168 settings from factory and meet the 90 psi @ 5.4 cfm rating.Pressures can be adjusted to a MAXIMUM 225/185 with a resulting lower cfm rate.I'm not familiar with "type 9". Likely nothing special just different setting from factory?
1/5/2020 2:37:30 AM • Dewalt Air Tools... • Answered on Jan 05, 2020
2answers
Dewalt 15 gallon air compressor will shut off it continues to run after shut off point. How do I fix it
What? If it won't shut off when it trips the limit valve. You need to replace the pressure switch.
10/25/2019 5:31:37 AM • Dewalt Air Tools... • Answered on Oct 25, 2019
Dewalt d55275 shows 120 psi, but won't run air tools
Not enough volume... if psi is good just increase the size of the line.
10/2/2019 9:37:04 PM • Dewalt Air Tools... • Answered on Oct 02, 2019
I have a PC 260C Finish nailer (2 1/2" to 1" length OK) with 1 1/4" Dewalt brads. Air compressor set on 80 PSI. Brads fire erratically if at all. More than half jamb. Sometimes 2 pins.
check your regulator to see that 80 is what the gun is receiving and if it is move to 90 psi
8/22/2019 1:46:31 PM • Dewalt Air Tools... • Answered on Aug 22, 2019
Dewalt power shop r1250 manual and parts for repair. where can i get the manual and order any parts i may need?
The box store pumps are usually sandborn pumps. I would find the model number and brand on the pump and go from there.
5/18/2019 11:55:39 AM • Dewalt Air Tools... • Answered on May 18, 2019
Dewalt cordless nail gun dc628 won't fire.
Try rearranging all the parts of the gun if possible. Clean them and try using them again , It should work.
5/12/2019 3:40:47 AM • Dewalt Air Tools... • Answered on May 12, 2019
Air comes out of top gasket its a d51822 dewalt
You will have to get a new gasket. I had the same problem but I had drop my gun.
5/3/2019 4:33:27 AM • Dewalt Air Tools... • Answered on May 03, 2019
Dewalt DC742KA Cordless 12-Volt 3/8-Inch Compact Drill/Driver Logo
1 questions posted
Top Dewalt Air Tools & Compressors Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Dewalt Air Tools & Compressors
Most Popular Question
download owners manual dewalt dc742ka
  • Air Tools & Compressors
