20 Most Recent
Sonic Impact Technologies Sonic Impact Video 55 iPod Player with 7-Inch LCD (Black) (5090) Questions & Answers
Tv not responding to remote
the remote may have dropped and there are 2 possibilities of fault.1-acrystal which gives accurate frequecy was broken2- the infrared sender led was burned or the printed cicuit connection for this IR led is broken
I have a Sonic Impact V55 Video player and a new
Absolutely, I have this myself. My 5th Gen works great, but the 160GB would not show movies, just played music. Apple has an adapter cable set that allows you to hook your Ipod to your TV. $50 buy it! You can charge and watch your stuff on your flat screen. It also unlocks your Ipod TV out setting for your Video 55. Set you IPOD video setting to TV Out: on, select your movie and play. Plug in the IPOD nip to your Ipod then set your Ipod into the Video 55. A bit of a pain but works flawlessly. If you select a different movie you have to do this all over again.
I have a sonic impact technologies sonic impact
The battery is rechargable for about 400x. If you leave it on the charger too long or never let the battery run down it will shorten its life span. Sonic Impact no longer sells the replacement battery unit through their website and I have been looking for replacements myself. the problem is this: the battery unit is integrated with the battery cover and can not be separated. So you need the actual Sonic Impact battery, and they have not responded to any emails, requests for customer support or phone calls. Good luck.
My sonic impact technologies sonic impact video 55
If you have a later IPod, 6th Gen or later, Apple changed the software and Sonic Impact no longer plays your movies, but audio is fine. You can get around this by purchasing, from Apple, and adapter cable. It is $50 but allows you to charge your Ipod and play your movies on your home TV. The cable is really just a key that unlocks the TV Out setting. If you have and 5th Gen or earlier then you probably just need to go into video setting and select TV OUT : ON. I hope this takes care of your issue.
I need a new battery, I can't find a supplier
At this time no need to find a supplier you just browse it in the website. I will recommend you this site to find your new battery.
www.ebay.com
Search the model of your battery and you can purchased it online. it better that you will know what is the brand of your unit ti easy ti find.
My Video 55 player will not play my videos
You need to switch the video out seeting on the iPod, simple. It is located in Video/video settings/TV Out. Change the setting to "On". Problem solved. However, if you have an iPod that is less than 1 year old, nothing will work, iPod blocked this ability to change to "On" and is set on "Off" permanently.
My iPod speakers have not
If it's an Apple product, you can guarantee that it's going to break, malfunction or whatever you want to call it. I say this because you have to have Apple fix it for 2-3 times the cost in fear of losing any warranty or Apple services moving forward. It's a great business method but not so much for the consumer's side of it.
Two problems with my Sonic
This is a very common issue with these Sonic Impact players, and even I personally have experience it myself. They are just poorly made, and the circuitry of the player does not agree with Apple iPod products, which sadly is what they are supposed to be made for. They seem to function fine for a few weeks, sometimes longer, but invariably they always start to "degrade" and eventually just stop working with the ipod altogether. I personally recommend you get rid of the player (sell it on ebay or something, just list that you have had issues with the buttons not always being responsive. Someone will buy it regardless) or just get rid of it to the goodwill.
If you are looking for a fairly inexpensive solution, I have had very good luck with Altec Lansing products, such as this one for $46 or so, shipped:
http://www.amazon.com/gp/product/B001AO1SRE?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B001AO1SREIf you are looking for something high end, Bose ipod docks are very reliable, and again their customer service is top notch, but the price point is much much higher:
http://www.amazon.com/gp/product/B001DLTDQC?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B001DLTDQC
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
