I have a Dynasty DGRSC range. It has 2 burners and a broiler. All 3 ignitors glow but the ignition is delayed. The burners are still ok.
if you are asking about the bake and broil igniters if they glow it doesn't mean that they're good,they work with amps,when the igniter pulls from 3 to 3.6 amps it opens the gas valve and then the flame ignites,easiest way to check them if they do ignite the flame is set it to bake,when the igniter starts to glow time it,if it takes longer than 40 seconds for the flame to lite the igniter is bad,also if you have two igniters for bake check the burner tubes,alot of times you'll see one igniter lites on time and the other is lazy,it keeps glowing and the heat burns a hole through the burner tube then you have to replace both the igniter and tube,you'll see the hole behind the igniter if it happens.it says your igniters are no longer available but you can use frigidaire or whirlpool but the frigidaire is cheap part 5303935066 i use this igniter in most ovens that have a flat igniter and it will work in your oven,the igniters come with ceramic wire nuts,just cut the wires from the old igniter and wire nut the new igniter to the wires,it's that easy,try to make the wires long enough so you can tuck them out of the oven,one more thing,the screws that hold the igniters onto the tube can be hard to turn,i wet a paper towel and wipe the threads on the screws,this makes a big difference the screws back out very easy when wet,you don't want to spray them with any chemicals because the heat will burn the stuff off and stink and could get into your food.good luck and hope this helps you out.
