20 Most Recent Radio Shack 3808 Digital Answering Machine Questions & Answers
What are the codes to remotely access my answering
The three-digit security code is on the label on the bottom of the machine.
8/11/2011 6:22:13 PM • Radio Shack 3808... • Answered on Aug 11, 2011
Hi there, Is there a way to record your own
The instructions for recording the outgoing message are on page 10 of the manual at
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4303808_PM_EN.pdf
8/10/2011 10:49:33 PM • Radio Shack 3808... • Answered on Aug 10, 2011
Need to re-record greeting -
The REPEAT/ANNC/DAY button.
Full details are in the "Recording the Outgoing Message" section of the manual (page 10 in my copy). If you need a manual, you can download one at
8/10/2011 10:18:24 PM • Radio Shack 3808... • Answered on Aug 10, 2011
Where can I get an
You can download the manual at
8/10/2011 10:16:08 PM • Radio Shack 3808... • Answered on Aug 10, 2011
Need set up for 43-3808A
8/10/2011 10:09:43 PM • Radio Shack 3808... • Answered on Aug 10, 2011
I just changed the 9v
The 00 means that the battery is low.
The A2 means that the time needs to be rest.
You can get the manual on the link below.
http://support.radioshack.com/support_phones/doc68/68590.pdf
7/4/2011 1:10:20 AM • Radio Shack 3808... • Answered on Jul 04, 2011
Lost manuel....how do I set
1. Turn on the system. Hold down
SKIP/TIME SET/CHECK. The
system sounds a tone after 1
second.
2. While holding down SKIP/TIME
SET/CHECK, press REPEAT/ANNC/
DAY. The system announces
"Monday" and &'?appears on the
display. Repeatedly press REPEAT/
ANNC/DAY until you hear or see the
correct day.
3. While holding down SKIP/TIME
SET/CHECK, press MEMO/2 WAY/
HOUR. The system announces "1
AM". &' appears on the display.
Repeatedly press MEMO/2 WAY/
HOUR until you hear or see the
correct hour.
4. While holding down SKIP/TIME
SET/CHECK, press PLAY/PAUSE/
MIN. The system announces "01".
Repeatedly press or hold down
PLAY/PAUSE/MIN until you hear or
see the correct minute.
5. Release SKIP/TIME SET/CHECK.
The system announces the day
and time you set.
6. To hear the current day and time,
press SKIP/TIME SET/CHECK while
the system is on or off.
Thanks!
3/29/2011 8:42:54 PM • Radio Shack 3808... • Answered on Mar 29, 2011
I have a Radio Shack
Looking at the manual
The code is NOT changeable as near as I can tell. It is written on a label on your unit.
When it answers, after it plays the message, you should type in that 3 digit code. Suppose it is 123.
You should type in 123 and then immediately enter the command you want.
Try 9# to record a memo, and see if it records. That is, type 1239#, and you should be able to record a memo I think the two tones is a misprint. Most of the time you enter the code either while the outgoing message is playing, or immediately after the outgoing message finishes.
3/23/2011 10:16:18 PM • Radio Shack 3808... • Answered on Mar 23, 2011
Set number of rings
If you have the Digital Answerer in White with Extended Recording Time TAD-3808, then slide the Ring Select switch on the right side of the unit to the desired number of rings. TS = toll saver and answers after 2 rings if there are new messages; , otherwise, it will answer after 4 rings.
All of the Radio Shack answering machne manuals can be accessed here: http://support.radioshack.com/productinfo/ProductResults.asp?Name=Telephone_Answering_Devices&ID=002004 .
For the 3808, see http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=43-3808&Name=Telephone%20Answering%20Devices&Reuse=N for the manuals.
I hope this helps.
1/15/2011 5:10:12 PM • Radio Shack 3808... • Answered on Jan 15, 2011
2answers
I need a manual for a radio shack digiial
Good Luck please rate 4 thumbs up and please leave a testimonial
10/15/2010 8:31:56 PM • Radio Shack 3808... • Answered on Oct 15, 2010
I have a radio shack 43-3808A answering machine.
Refer to Manual for reset code utility... To do so go no Google and type download RS-3808 digital answering machine then take the one you need ..good luck
9/30/2010 10:36:21 PM • Radio Shack 3808... • Answered on Sep 30, 2010
3808 Digital Answering Machine: I have lost my instruction manual to Radio Shack 3...
look in the internet for the manual
5/7/2010 10:46:25 AM • Radio Shack 3808... • Answered on May 07, 2010
How do you add your own message? How do you set the time and date
I solved the problem because I found my mannual.
1/12/2010 11:27:16 AM • Radio Shack 3808... • Answered on Jan 12, 2010
I have been given a RadioShack Digital Answering
You can get that at the link below:
http://phone.manualsonline.com/ex/thread/view/idThread/1759807
10/5/2009 3:07:08 AM • Radio Shack 3808... • Answered on Oct 05, 2009
Pick up calls from another location
Manual - http://support.radioshack.com/support_phones/doc65/65505.pdf
SECURITY CODE
To use your system from a remote telephone, you must first enter
a 3-digit remote operation security code. The security code
label is located on the bottom of the system. Enter the security
code after the system answers and sounds two tones. Within 7
seconds, enter one of the remote commands
OPERATING THE SYSTEM FROM A
REMOTE LOCATION
Dial your phone number. Even if the system is off, it will turn on
and answer after about 10 rings. After the system sounds a
tone, enter your remote operation security code. Enter a remote
command (see “Remote Commands” on Page 19). When you
finish, press 5# to end remote access.
REMOTE COMMANDS
Note: When listening to messages in remote mode, there is a
pause during playback every 2 minutes and 40 seconds. Press
0–9, #, or * to continue playing the message.
Press To
1# Play new messages.
2# Play all messages.
3# Delete the current message.
4# Repeat a previous message.
5# Stop and exit.
6# Skip a message.
7# Turn on/off the system.
8# Record an outgoing message.
9# Record a memo.
0# Monitor the room.
Hope this Helps... Have A Nice Day... :)
11/1/2008 3:16:52 PM • Radio Shack 3808... • Answered on Nov 01, 2008
Digital answering machine
Hi Bibi - Is this a regular land line? Is the fax machine supposed to answer if it's a fax but not answer if it's a phone call? Let me know exactly what your mothers' setup is please. It sounds to me like the fax is trying to answer all the calls and the screeching she hears is the fax machine try to handshake, or connect, with another fax machine. You've probably heard what that sounds like. Let me know the answers and if you can ask some people that called if they heard anything. Thanks.
Jeff
9/25/2008 3:36:01 PM • Radio Shack 3808... • Answered on Sep 25, 2008
2answers
Radio Shack 3808 digital answering machine
You can download the manual from the link below: http://support.radioshack.com/support_phones/doc65/65505.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
8/25/2008 5:12:13 PM • Radio Shack 3808... • Answered on Aug 25, 2008
Radio Shack 3808 Digital Answering Machine Logo
Popular Tags
30 questions posted
Top Radio Shack Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Radio Shack Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Radio Shack Lands Phones
Most Popular Question
get
  • Lands Phones
