20 Most Recent
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Questions & Answers
Bluetooth "device out of range or powered off"
I had lots of trouble too. I thought it was my phone. Well here's what you do. First off remove the device completely from your phone. Turn off the phone and take the battery off so it can re-boot. When the phone is powered back up put your bluetooth in pairing mode and get it back on your phone. It should connect without any problems. Now....here is the trick. When you want to disconnect the device(bluetooth) from your phone don't turn it off on your phone. Shut the actual power off on your bluetooth. The phone will recognize this and disconnect the device. The only thing left on your phone will be the bluetooth icon. Being the icon still on your phone it is still in discovery mode and can overtime use up your battery life searching for a device. This is when you can go to your phone and turn off the bluetooth. On your NV 2 go to your bluetooth menu and just use your left softkeyto turn it off. Now there is no connection whatsoever. And to turn it back on do the opposite. Go to your bluetooth menu and turn on your bluetooth. You will see the bluetooth icon. Now you power up the bluetooth and it will connect as soon as it get the signal. This took me 2 weeks of trial and error and other stuff but I am happy now and I hope this solves any bluetooth problems...
Bluetooth wont charge or power on. when charging
Indicator Lights:
1.Headset Status Headset Indicator Light2.Powering on Steady blue, then intermittent flashes(changes to standby mode)3.Powering off Red appears and goes off4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off whenbattery is fully charged and headset is off.6.Low battery Triple red flashes7.Pairing mode Blue/red alternating flashes8.Missed call Purple flashes. Press the call control button
to cancel flashing light.9.Incoming call Triple blue flashes when ringing.Power on and off:1.Turn on the headset Press and hold the call control button until theindicator glows blue. You will hear ascending
tones.2.Turn off the headset Press and hold the call control button until theindicator glows red. You will hear descendingtones. When power is off, indicator stays off.If
none of this is helpful then it may be that your battery is dead, if
that is the case then you will need to replace the whole headset. The
battery's are not replaceable.Good luck from
Headsets Direct!
I have had this bluetooth for a while but never
The default pass code is "0000."
Here's how to pair it with the default pass code:
- Turn the Bluetooth on and hold down the button until the light turns solid.
- Put the phone in discovery mode or search for a Bluetooth device.
- Pair the Bluetooth to the phone and enter the pass code "0000"
