Hi.
Try first disconnecting the power cord for ten minutes, and ensure that the problem is not the source device connected to TV (receiver, DVD...).
Check connection cable, and test different sources on different connections.
If that does not fix the problem, then you may have one of the following faults:
The LCD ribbon cable/LCD display and connectors.
This
is quite uncommon, but happens. If the TV had been hit or moved the LCD
cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This
is the board that controls the video signal, it is difficult to test,
as there is need to read determined values on IC pins. To test this
board you need to purchase a service manual and follow the
troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you
connect the video and audio cables. On most LCDs this functions are integrated on the Main controller board, like on your Sharp. If a signal I/O circuit is defective,
then you may get no picture and lines only on a particular input located on faulty
board, or on all inputs.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here:
Electronic Replacement Parts: Plasma & LCD TVs, Appliances
