20 Most Recent
PANDIGITAL 6.0-Inch Digital Picture Frame w/Black Wood Frame (892235000623) Questions & Answers
Picture frame won't turn on
I would think sometimes it requires time to Charge the Battery before happy face on screen comes on...loL :). Try to plug in adapter cable, or power cable, and leave it plugged in for a bit. Then try again later :)
Transfer pictures from memory card
Ok what you need to do is you need to put your memory card into your computer/mac and down load the files once that is done delete the photos on your camera!
How to get a photo to pause
View Individual Photo
1. On the photo thumbnail screen, use ? / ? to highlight a photo and then press ENTER to view it individually.
2. Press EXIT to return to the photo thumbnail screen
I need the Instruction Manual regarding how to use
You might have 2 chances to find one. You can google it and download it, if a site has it. Otherwise, you will have to contact the manufacturer. Only other choice is finding someone who has it, and make a copy.
How do I load my
I could not load my directly directly from PC. I had to put them on my camera memory card, then insert memory card into frame. worked well but took more time.
Why My trittOn warhead 7.1 headset port keeps blinking
There are a couple things that could blink on a Tritton Warhead 7.1 headset:
1. The round quadrant on the base station
2. The sync button on the headset piece itself
On 1. That means you have to sync it with your Xbox. Press the button on the Xbox that you would usually pres to sync a controller (it kind of has 3))) on it) and then press the sync button on the base station. they should sync up, then you have to press the ( 3 ))) ) ones on the inside of the headset until the quadrant on the Base Station is the same as on your controller.
2. that means that the headset is not connected to the base station. Try to unplug it form the power socket but if you get no lights on the base station at all it might be faulty or the power adapter might be faulty
You get 2 yars of warranty from the purchase date so submit a ticket on support.madcatz.com
