20 Most Recent
Coby DP-768 7-Inch Widescreen Digital Photo Frame with MP3 Player & 2 Wood Frames Questions & Answers
I have flipped my photos
Hey there Coby you best settle down and be calm, ok now what cha gotta do is rotate them either 90 or 180 degrees. See to easy.
Digital Royal Key Chain - How do I download
Hi, the Digital Royal Key Chain has a mini USB port located somewhere, this should also be the port for the adapter to the built in lithium battery inside. There after, just plug in your computer and Plug and Play software should detect it. Then you can move your picture files, (.jpg, .mpeg, .gif, etc) and drag them in the drives folder. They should display then.
Does the digital photo frame have it's own
Most digital photo frames have a small internal memory limiting you to the amount of pictures that it can show. If you want to have a slide show of a couple of hundred pictures or more then an SD card would be a good idea.
Regards.
I do i get pictures from my camera to my digital from with my usb
hi you can plug in your secure digital card into the digital frame,or if your camera does not use a secure digital card,you will need to buy a memory pen stick where you can store any picture you want on it,they are very cheap and they just plug into your usb port,hope this helps
Full frame??
Hello to all. Well after a few tries I figuered it out, all you do is hold down the arrow pointing > to the right at the back and thats it full screen, I guess pressing the arrow < pointing to the left reduces the size again. Just remember to hold it down for a few seconds.Hope I was helpful, take care all.. Happy Holidays
