20 Most Recent
Coby DP-888 8-Inch Digital Photo Frame with MP3 Player & 2 Wood Frames Questions & Answers
Hi, I was given this
Chuck it and go shopping. Coby also out of business so getting parts is also not likely.
Omnitech 8.5 Digital Photo frame...no Instructions
I had this same problem and after playing with it for several hours, I discoverd the software that came with the frame was copying my photos to the "D" drive. Since my frame was connected to my computer through the "g" USB, of course the photos were never copied. So I went the the Smartparts software (that came with the frame) and found the folder which was saved on the "d' drive. I then did a simple "copy to" "g" drive (this is where my frame was connected to. If these instructions are clear, ask again and I will try to further help you. Good Luck!
Screen is very dark, cannot see pictures! And
Attempt by going in a complete dark room with no lights, and see if you can see the screen at all to atempt to access the menu, sounds like that the Brightness or Contrast was adjusted too far. If that doesn't work, reccomend trying to take to place of purchase and exchange for new one.
Miller Photography
www.millerphoto.ca
Have a kodak ex811 digital frame
utf-8
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Once you connected your EX811 to your computer, and get the
message “Use PC interface to copy files.” That means you can start copying files.
Here are the steps:
Copy pictures, videos, and music between
your frame and computer, using your computer's normal file copying tools:
1. Connect the
USB cable from the frame to your computer
2. On your
computer, open My Computer or Windows Explorer.
The picture
frame appears as removable drives—one drive for each connected picture source
in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to
the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Film won't load on Vectis 300 MinoIta
The clue is in your descrition; Old.
If the mechanism has jammed, due to age or lack of use that causes tarnisg=hing on the contacts, the motor/mechanism will not load.
I would get it serviced at an aurgorised Minolta repair shop.
Contact Minolta for a list of authorised repairers.
3/22/2024 7:04:40 AM •
Photography
Answered
on Mar 22, 2024
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
- Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
- File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
- Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
- Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
- Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
3/16/2024 9:30:07 AM •
Photography
Answered
on Mar 16, 2024
