20 Most Recent
Thermos Grill2Go Fire+Ice Questions & Answers
My Grill will no longer lift
I just had mine apart today because the cable broke. There is only one damper, in the left side where the pedal is. The other side is controlled by a cable that is strung on rollers. My cble broke so i had to replace it with one from a hardware store. I noticed that everything needs to be oiled for the system to work good. The gas strut/damper is inside of the lift tube. I would think it could be matched up with one from an automotive store. Autozone has a pretty good selection of them. But, The strut that is in the grill has a special end on it to fit the lift tube, you would have to somehow fabricate a new end or try to cut and weld or braze the old one onto the new strut. I have not had the strut problem yet because when I store the grill I leave it in the up position. this takes the stress and pressure off of the strut. Hope this helps.
Pedal does not bring up grill
If you can still raise it manually, it probably needs new hydraulic struts. Mine actually never worked from new, and I am taking mine apart today to fix it. I will let you know what the part number is of the strut.
One side of the grill base will not rise up
One one side, there is a gas strut which is connected to the other side via a cable, similar to that which you would find on a bicycle for the brake. When the strut side raises (it uses this cable and a series of pulley's) it shortens the cable and raises the other side. With use, this cable where's and can slide off the pulley. It could also be that this cable has been damaged, although the prior is more likely the case. It's fairly easy to disassemble and inspect. One regular and one small philips screw driver, along with a pair of needle nose plier are all the tools necessary. If you would like further info. please let me know.
What was cost brand new?
I paid it new in 2005 400 AUS in Melbourne. I think value is now 100 AUS (depends from the conditions.I need the grate (mine is broken and I can't use it anymore): If you sell to me all at 50 Euros + Expenses, I can buy it. I cannot find parts anywere....
Grate grill
yes, it is but the manufacturer does not make this available. we have to use other grates that just happen to be the right size and install using the same kind of support.
