20 Most Recent
Kodak Easyshare G600 (1633379) Dock / Cradle Questions & Answers
Ink cartridge stuck printer
The manual says: To remove the cartridge, push up on the Cartridge-release tab then pull out the cartridge.
It looks like a green lever to me, you have to push.
Do i need a camera
No. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Can't remove used ink cartridge from G600 Printer dock???
I found a how to video on the web.Turn off your printer. Hold down the left arrow button and transfer button at the same time, then turn your printer back on. You should hear it make some noises, open side door push on cartridge to see that it is locked in. Then hit the green release button on the inside and the cartridge should come out on its own.
Charge batteries while camera is docked
what is the model of your camera and what specific battery are you using( what is on the label of the battery?)
when the camera is docked on the printer, you should get a little light indicating the charging status. Once it is fully charged, all 3 green lights would come on.
But, we need to know what is the model of your camera and what type of batteries are being used in order to determine if they are compatible or not.
