20 Most Recent
Aspire (ATX-AS500W-BL) (atxas500wbl) 500-Watt Power Supply Questions & Answers
Acer Aspire 7004 wmsi Will not start.
When you press the power button does anything happen? such as lights or LED's illuminate?
You could try the following -
1. Make sure there is nothing plugged into the computer (USB devices or memory cards etc etc).
2. Remove the power cable & the battery
3. Press the power button for 30 seconds
4. Insert the charger but not the battery and try and start it up.
If that doesnt work check the USB ports for damage and the port where the charger is plugged in aswell.
If they are damaged or it still wont start it will probably need repairing.
1/18/2009 4:11:51 PM •
Aspire...
Answered
on Jan 18, 2009
I did a factory reset on aspire r11 r3-131T and now windows wont load
Hi there, I would advise you to access the Acer eRecovery option by holding down Alt + F10 after restarting your laptop. This will give you an option to run the recovery outside of windows. Make sure you do not have any USB devices plugged in like a flash drive or mouse. These devices use drivers that can halt the installation of windows. Good luck!
