20 Most Recent
Dell Inspiron 8000, 8100, 8200 Series Laptop Hard Drive Caddy (GPOHD-D8000 Caddy) CD-ROM Drive Questions & Answers
No sound with or without earphones, mute is not on, device manager ok
thanks for you problem,
i think i can help u.
dear frn, don't worry, if device manager looks fine altho you are no able to hear the sound then it is better to uninstall the software driver then reinstall it. coz, if any files of driver is deleted then also it help u to repair it, so plz reinstall the sounddriver. i hope it will ok fine.
ok have a nice day.
good gyee
After starting M1104 error is written on screen why because of that my system is become more slower
dont know what this error message relates toclick start control panel administrative tools computer management then select event viewer depending on what operating sytem you have this may vary extend the events there you will see errors in red you will no what exactly what the error was and you might be able to work your way through the problemif you need more help with this post a reply with the error message detailshope it helps
How do i unlock a dell laptop
if you are using xpRestart your computer during the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears.
Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system.
Press ENTER. Shortly, the welcome screen should show. Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows. hope this helps you
I do not have a cd for the operation of the cd or
Hi there,I think it would be best for us to start a remote support session, so that I can see the screen of your computer and solve the problem for you.To get started, click on this link to download the remote support program to your pc
http://www.teamviewer.com/download/version_4x/TeamViewerQS.exe save it to your desktop for example, and double click on its icon to start it. Send me the ID and password number it gives you.and I'll connect within few minutes to solve the problem.Note that the program has to be kept open or I won't be able to connect.
Slow downloads and freezes
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then click start all programs accessories system tools defragment your hard drive
you might have to install more RAM random access memory to check how much ram you have
to check the details on your computer
click start all programs accessories system tools system imformation you will see all of your computers imformation from there another way of doing this
click start right click on my computer select properties you will see all imformation about your computer including installed ram
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer if you see something running that you don
Reinstalling xp will not take my product key
If you are reinstalling Windows XP from a NON-DELL disc, and trying to use the Dell OEM product key, it will not work.
OEM versions of Windows have a modified precopy2.cab and a retail version of XP will not validate the OED product key from the chassis. This is because the OEM media for Dell has a precopy2.cab that pre-loads the product key when the system is BOOTED to the OEM media (It also pre-activates the OS)
Your choices at the point are:
- Re-install the OS from a Dell OEM CD (They can be purchased on EBay for around $20, and only work on Dell Systems)
- Purchase a valid Retail Key from Microsoft
I have a Dell inspiron
the only recommended way at this stage is to loose the CD Rom with a screw driver. I have done this couple of times when I was trying to fix my CD Rom.
Get a screw driver and unscrew the screws from the under of the drive so that the up cover can be removed and you can gain access into the CD Rom thereby enabling you to remove the disc inside.
If the drive is difficult for you to loose, I would advice that you study it well because its loose able, just give it some more effort and you will eventually succeed in loosing the CD Rom cover.
As for the repairs, its rear for CD Rom in a condition like this to be repaired, therefore, I would advice that you get another one.
The CD Rom for my laptop just stopped working for no reason and I loosed it and did all I could, but but no avail. I still ended up getting another CD drive.
I wish you the best of luck.
Take care.
Thanks for using FixYa.
You need to take out the optical drive and open it up to recover the CD that you need out. You also need to replace the optical drive because it already reached its end of life (gears inside are already bad). If you have knowledge in taking out the optical drive from your laptop then that's good. If not you can try to take out the screws under the laptop that holds the optical drive in place. Pull the release latch and you should be able to take it out. If you are having problems trying to do this. Just buy yourself a replacement for the optical drive and Im sure that the shop that you bought it from will be more than happy to replace the drive themselves. It will take no more than 5 minutes to do this. After they take out the optical drive. You can probably start being a surgeon and take out all the screws from the optical drive and take out parts piece by piece until you get your CD out. Warning, its really fun to be a computer part surgeon, just don't try it on your new optical drive... hehehe, cheers!
I hope this helps. Happy new year! or happy new decade rather! =)
- HotRatchet
My CDROM drive is stuck and doesn't open, how
Hi jameelahn,
Your going to need a very technical tool to fix this. Get a paperclip and straighten it out so you have about 2". Near the CD-ROM push button, you'll see a tiny hole that only a paperclip size pin will fit. Gently, put the paperclip into the hole, and gently push until the drive opens up.
To repair the drive, you will need to tell me what is wrong with it.
Thanks Mark
Windows xp -
See links
here and
here.and
here.I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Gray screen
alternate click on " MY COMPUTER" then properties, the hardware, then device driver, click on video , alternate click on the unit and select updae driver
Dell inspron 8100 laptap with windows xp
Try booting with your windows xp installation cd in the drive. See if it will give you a repair or restore option when doing this. If it does not then it's possible your computer has a virus. You can check this by booting up with your anti virus cd in the drive and let it do a system scan. Hope this helps & please remember to rate my answer. Thanks.
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here.
Larry Ng Jun 23, 2022
NO PC told (dell has 10000 models)
no OS told, windows what"?
no drive told.
my wild wild guess is the boot drive is locked.
and you are attempting and ******* act. to it.
like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails)
no real goal told, but the nebular "install HDD"
one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact)
but the boot drive , change out is far far far more complex. and you never not told that.
you want to mess with the C: drive?
now let me guess the real goal (sad I must)
the OS drive windows is failing ( common)
and some lil' bird told you it needs a new boot drive, and then fail to say so here.
okay I will bite.
1: buy a new SSD (hdd fail and are slow)
2: buy a new OS, from MS. or get free w10. (ask how)
3: then put in new SSD,
4: run the w10 installer media (it is free)
5: load w10 to the SSD fresh
6: answer the silly 30 questions it asks.
7: and click activate. (buy it)
How do i change admin password
can;t log in now or what?
what does change mean,
lost it and now can not get in
or means just want to change it , logged in.
NO PC told and NO OS told
or if bios admin or windows admin.
bios or windows.
both are hacking./ if lost.
so google the cure.
