20 Most Recent Street Glow Streetglow Streetglow H885 Headlight Replacement Bulbs Questions & Answers
1999 Isuzu Rodeo both front headlights stopped working
could be problem relays or light switch
10/23/2021 6:21:17 PM • Street Glow... • Answered on Oct 23, 2021
How do u change front headlights on a 2011 silverado
Go to YouTube. There is a how to video on there.
7/24/2014 10:11:13 PM • Street Glow... • Answered on Jul 24, 2014
Isuzu rodeo one headlight lowbeam
What exactly is the problem? Please specify your problem...
12/30/2013 11:50:27 PM • Street Glow... • Answered on Dec 30, 2013
Okay so the other day
  • Check the headlamp wiring
  • Check if the fuse amp. is proper
  • If there is any shorting in the wires then the bulb will glow but it will become dim
2/26/2011 3:52:10 PM • Street Glow... • Answered on Feb 26, 2011
No Lights On Low Beam
check the fuses on the car
a little more info will help give a more detailed fix
5/29/2010 2:01:53 PM • Street Glow... • Answered on May 29, 2010
I have no headlight on right side why?
i had a crossfire with the same problem, I pulled the globe and the headlight just to find that there are individual fuses for left and right, double check your fuses before replacing the globe, good luck
1/1/2010 3:28:02 AM • Street Glow... • Answered on Jan 01, 2010
I have a 1998 Isuzu Rodeo The head lights won't
The dimmer swich is suspect, Its mixed in with the turn signal switch wiper switch. sometimes it can be found watching the lights to push in and wiggle the turn signal switch if it comes on low at all doing this the switch is bad. It fails alot everyauto parts store should have it and take the covers off the collum to change it don't forget to check the plug that plugs into the switch for burnt connectors or backed out wires. find the wire that comes hot when you put power right on the low beam wire on the headlight ( lows will be on ) there'll be a wrre that came hot that wasn't with every thing hooked up, Unhook jumper and hook right at switch if it works from the switch the switch is bad. Change and ride saftly at nite. Some models have daytime running lights and the fuses for them are in their own fuse panel and have heir own relay this doesn't happen very often.
8/11/2009 4:57:32 AM • Street Glow... • Answered on Aug 11, 2009
I have a 97 grand am with DRL problems
Not a short. FIRST check your battery connections. These can get corroded and turning on the headlights breaks the corrosion enough to allow power to the system.
7/27/2009 4:33:15 PM • Street Glow... • Answered on Jul 27, 2009
Gathers car audio manual
How to change language to english for Honda Odyssey 2021 Gathers Radio Player
4/16/2024 4:19:39 PM • Car Audio &... • Answered 3 hours ago
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
3/26/2024 3:40:48 AM • Car Audio &... • Answered on Mar 26, 2024
2answers
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
3/19/2024 7:56:21 PM • Car Audio &... • Answered on Mar 19, 2024
What demo mode the code for 4.91
'make model (what is is)' as first 3 words in all questions. https://www.google.com/search?q=demo+mode+the+code+for+4.91 ..
3/19/2024 2:42:25 AM • Car Audio &... • Answered on Mar 19, 2024
Xplore Amp 5553. How many watts RMS and impedance loads.
Unfortunately, no one knows or is telling. Companies rarely state power in RMS because Peak Power is a much more impressive. 1000 watt amp, 200 watts RMS x 2 channels at 8 ohms. Look for a sticker on the unit. https://www.google.com/search?q=Xplore+Amp+5553 ..
3/19/2024 12:23:13 AM • Car Audio &... • Answered on Mar 19, 2024
Carrozzeria serial abm760p57 RADIO ON ??
What is your question? Thank you.
2/28/2024 7:23:47 AM • Car Audio &... • Answered on Feb 28, 2024
2answers
I need the code
Your code is 1 3 6 3
2/25/2024 10:20:30 AM • Car Audio &... • Answered on Feb 25, 2024
Street Glow Streetglow Streetglow H885 Headlight Replacement Bulbs Logo
25 questions posted
Top Street Glow Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Street Glow Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Street Glow Car Audio & Video
Most Popular Question
1998 isuzu rodeo head lights
  • Car Audio & Video
