20 Most Recent
Hamilton Beach 70610 10 Cups Food Processor Questions & Answers
Hamilton beach food processor won't turn on
DYI fix job on mine. DIsassembles base and switch assembly. Added a rectangular piece of plastic just above litlle balck trigger switch. Taped switch casing's side (not my plastic piece) so that my plastic piece would not fallout. Re-assembled. Voil?. Problem was that travel length of whole trigger mechanism was a bit too short to trigger the switch. With the added plastic piece, travel was extended a little to make the whole thing work, but not so much so that it would always unsafely stay ON when plugged. Tried various other gluing options on other pieces before that, but nothing would hold.
I need to replace the timing belt on my Hamilton
Hi, if you were to put the belt on with the teeth facing away from the wheel, are there any sort of cogs for the teeth to connect to? if not, then the belt needs to go on, teeth touching belt, i hope that makes sense
