20 Most Recent Sears Kenmore Elite 4.2 cu. ft. Front-Load Steam Washer featuring Smart Questions & Answers
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its a faulty CCU that needs to be replaced. Here is the part.
Sears Kenmore... | Answered on Oct 20, 2012
It could be possibly the belt. or if not, possibly a wire grounding out.
Most likely the belt. If the motors on a bind or going bad, it can smell like that also
Sears Dryers | Answered on May 27, 2014
element or stats
Sears Dryers | Answered on Apr 03, 2014
The heating element is burned out and needs to be replaced
replace timer
Sears Dryers | Answered on Nov 11, 2012
With an electric clothes dryer, no heat often means that the circuit breaker or fuse that controls the power has blown; reset or replace it. Be aware that a dryer may have two breakers or fuses. The motor will run when one works, but the heating element requires both.
https://www.hometips.com/repair-fix/clothes-dryer-doesnt-heat.html
Dryers | Answered Yesterday
https://www.youtube.com/watch?v=Ft7lXDPCEug
Dryers | Answered 3 days ago
Hi, Lori for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can not find the best tool you ever bought for your DeVilbiss, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://www.google.com/search?q=Heat+element+Devilbiss+145&sxsrf=ACYBGNTBMENsgLoP6muXPqPn2G_GFa21Kw:1580963183957&source=univ&tbm=shop&tbo=u&sa=X&ved=2ahUKEwiv9-3nirznAhVwx1kKHSjjAPIQsxh6BAgMECw&biw=1440&bih=757
https://www.google.com/search?sxsrf=ACYBGNTBMENsgLoP6muXPqPn2G_GFa21Kw:1580963183957&q=Heat+element+Devilbiss+145&tbm=isch&source=univ&sa=X&ved=2ahUKEwiv9-3nirznAhVwx1kKHSjjAPIQsAR6BAgKEAE&biw=1440&bih=757
http://www.frankshospitalworkshop.com/equipment/documents/oxygen_concentrators/service_manuals/DeVilbiss%20515%20Oxygen%20Concentrator%20-%20Service%20manual.pdf
https://www.ebay.ca/sch/Collectibles/1/i.html?_ssc=1&_nkw=devilbiss+145
https://images-na.ssl-images-amazon.com/images/I/71xm4l0DhJS.pdf
Dryers | Answered on Feb 06, 2020
Not familiar with that exact model, however it is a momentary push on/off then there's a run relay that energizes and holds a set of run contacts closed until interrupted by the off push button.
Dryers | Answered on Feb 04, 2020
the capacitors start the motor. it wont run without them unless youd like to push start the fan every time you try to run it.
https://www.repairclinic.com/ProductDetail/611659?tab=problems
Dryers | Answered on Feb 03, 2020
do you have forced hot air heat and a very tight house? is the dryers vent flap closed?
Dryers | Answered on Feb 01, 2020
I have owned the same dryer for about a year and just started having this F03 problem. The condensation drain hose is the soft flexible rubber hose coming out of the back of the dryer and it drains into the same drain as a washer. It's easy to pull the hose off its connector at the back of the dryer and just blow hard into it to make sure there's no lint clogging the hose and reconnect it to the dryer. Next open the panel on the left of the dryer and thoroughly rinse (water only, no soap) clean the two parts behind the door (first is plastic and behind that is the condensation filter which probably is loaded with lint). Sometimes the lint in the condensation filter channels (those that run from front to back) can be quite stuck. Use a long pipe cleaner to get in there or a garden hose with a spray nozzle. Shake the excess water out of the condensation filter and dry off the outsides of two parts. Clean all the lint out the compartment where the parts go. There is one more crucial step not mentioned in the manual. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver or a blunt table knife under the panel and gently pop it open. Under the panel is a small chamber that you can't see very well where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Use paper towel to get it all out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place as well as the condensation filter and the plastic part. Take out the lint filter (within the dryer drum compartment) and wash it with soap and water. Use an old toothbrush or something to clean the screens thoroughly. Rinse well and dry it completely. Clean all the lint out of the empty compartment. Put all three parts back into the dryer. Clean all lint off the door. Using paper towel moistened with white vinegar clean the two metal sensors in drum compartment on the front wall and lower left. Run the dryer empty but with heat on for a few minutes to make sure all the water is drained out. Now try drying a load. I think it's a good idea to rinse clean the condensation filter at least once a month since it collects a lot of lint. Hope this works for you.
Dryers | Answered on Jan 30, 2020
Sears Kenmore Elite 4.2 cu. ft. Front-Load Steam Washer featuring Smart Logo
8 questions posted
Top Sears Dryers Experts
Andrew Taylor
Andrew Taylor
James Steuber
James Steuber
Level 1 Expert
Are you a Sears Dryer Expert? Answer questions, earn points and help others
View Most Popular
Sears Dryers
  • Sears Dryers
Most Popular Question
flashes error code f06
  • Dryers
