20 Most Recent Sears Kenmore 6.0 cu. ft. Gas Dryer, White Model 70022 Questions & Answers
Some panels can't be removed from the back but from the Top and Front only. Check the Front and the Top
Sears Kenmore... | Answered on May 27, 2014
It could be possibly the belt. or if not, possibly a wire grounding out.
Most likely the belt. If the motors on a bind or going bad, it can smell like that also
Sears Dryers | Answered on May 27, 2014
element or stats
Sears Dryers | Answered on Apr 03, 2014
The heating element is burned out and needs to be replaced
replace timer
Sears Dryers | Answered on Nov 11, 2012
PERHAPS IF WE KNEW WHAT THE DEVIL IT IS BUT ALAS YOU DIDN'T MENTION THAT ,DID YOU?
Dryers | Answered 6 hours ago
HOW WOULD ANY ONE GUESS WHAT YOU HAVE ASK THE MFG ONCE
Dryers | Answered 2 days ago
Possibly Cissell - if that is the same brand name instead of Cassell. Same question asked many times without answers according to search using https://www.google.com
Possible manual at the link below, but hard to known without model number:
https://www.manualslib.com/brand/cissell/dryer.html
belt or drum roller issues
THERE IS NO RESET
Dryers | Answered on Jan 14, 2020
Either your switch, relay, Resistor or blower motor is bad. You can test them all.
Dryers | Answered on Jan 13, 2020
then call your local repair shop if you can not figure out how to get to it
Dryers | Answered on Jan 10, 2020
Buy yourself a high current in line switch.
Have some one take the cord out for you.
Place the in line switch in the socket and plug in the cord.
You don't have to take the cord out.
Only switch the in line switch off.
Think Air FLOW. Air flow actually cools during normal use, so if flow is restricted, temps go beyond limits. Not what you want.
Here is an easy test: Pull dryer away enough to pull the exhaust hose off... Activate the dryer and form an opinion of the volume of air flow out of the back of the dryer.
Turn off, hook up the hose, Turn on again, go outside and likely you will find substantially lower air flow. I have seen installs that use a grill on the exit from the house. These clog up almost immediately.
Get the air flow working, your drying will be better.
My bet is something is clogged.
Dryers | Answered on Jan 08, 2020
Sears Kenmore 6.0 cu. ft. Gas Dryer, White Model 70022 Logo
1 questions posted
Top Sears Dryers Experts
Andrew Taylor
Andrew Taylor
James Steuber
James Steuber
Level 1 Expert
Are you a Sears Dryer Expert? Answer questions, earn points and help others
View Most Popular
Sears Dryers
  • Sears Dryers
Most Popular Question
removing panel install conversion kit
  • Dryers
