20 Most Recent Sears Kenmore Elite Electric Dryer 69278 Questions & Answers
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Sears Kenmore... | Answered on May 14, 2016
This would indicate you have a lint build up somewhere in your exhaust system. The best way is to disassemble the unit and completely clean the unit. Also remove the exhaust hose and make certain it is clear all the way through and that the exit door is not blocked closed or plugged inside. I normally do this annually and then use a long brush to clean monthly to maintain a safe, functioning unit.
Sears Kenmore... | Answered on Nov 07, 2015
this sounds like someone has switched the wires on the door switch.
Sears Kenmore... | Answered on Aug 28, 2015
If light stays on when fully closed, door switch needs replacement, easily removed. Short term fix, disconnect the switch and tape the two spades together. Warning! Dryer will run even with door open.
Sears Kenmore... | Answered on Dec 02, 2014
Could be either the heating element or one of the sensors on the dryer.
Try cleaning out the main duct along with the filter on the top or inside
Sears Kenmore... | Answered on May 27, 2014
It is most likely the water pump on the washing machine. Check the hot and cold hose and make sure there are round gaskets on the inside of them and that they are tight on the hot and cold valves.
Also check the drain hose that it doesn't have any holes in it and that the hose is far enough down into the drain . If all that's ok, it's your water pump.
It could be possibly the belt. or if not, possibly a wire grounding out.
Most likely the belt. If the motors on a bind or going bad, it can smell like that also
Sears Dryers | Answered on May 27, 2014
element or stats
Sears Dryers | Answered on Apr 03, 2014
The heating element is burned out and needs to be replaced
replace timer
Sears Dryers | Answered on Nov 11, 2012
If no lights, make sure there is power at the outlet. Plug in some other device into same outlet to test.
Check bucket switch. See link for more.
https://www.repairclinic.com/ProductDetail/939653?tab=problems
Dryers | Answered Yesterday
With an electric clothes dryer, no heat often means that the circuit breaker or fuse that controls the power has blown; reset or replace it. Be aware that a dryer may have two breakers or fuses. The motor will run when one works, but the heating element requires both.
https://www.hometips.com/repair-fix/clothes-dryer-doesnt-heat.html
Dryers | Answered 2 days ago
https://www.youtube.com/watch?v=Ft7lXDPCEug
Dryers | Answered on Feb 14, 2020
Sears Kenmore Elite Electric Dryer 69278 Logo
10 questions posted
Top Sears Dryers Experts
Andrew Taylor
Andrew Taylor
James Steuber
James Steuber
Level 1 Expert
Are you a Sears Dryer Expert? Answer questions, earn points and help others
View Most Popular
Sears Dryers
  • Sears Dryers
Most Popular Question
sears electric dryer flashing f01 wrong
  • Dryers
