20 Most Recent
Fisher Paykel Fisher & Paykel AquaSmart WL42T26CW1 25" Top-Load Washer with 3.1 cu. ft. Capacity, 19 Wash Cycles, Load Sensing, Auto-Lint Disposal and Stainless Steel Bowl Questions & Answers
Defy twin tub 1300 brake cable snapped
Defy Twin Tub 1300 washing machine, it is important to address the issue promptly to ensure safe and proper operation of the appliance. Here are some steps you can take to address the situation:
Safety precautions: Before attempting any repairs, ensure that the washing machine is unplugged from the power source to prevent any electrical accidents. Additionally, make sure to wear appropriate protective gear such as gloves to avoid any injuries.
Identify the brake cable: Locate the brake cable within the washing machine. It is usually connected to the motor assembly and is responsible for engaging and disengaging the brake mechanism.
Obtain a replacement brake cable: Contact the manufacturer or an authorized service center to obtain a suitable replacement brake cable for your Defy Twin Tub 1300 model. They will be able to provide you with the correct part that matches your specific machine.
Remove the old brake cable: Depending on the design of your washing machine, you may need to disassemble certain parts to access and remove the broken brake cable. Refer to the user manual or seek guidance from the manufacturer's technical support for detailed instructions on how to remove the cable safely.
Install the new brake cable: Once you have the replacement brake cable, carefully install it by following the reverse steps of the removal process. Ensure that the cable is properly aligned and securely connected to the appropriate components.
Test and verify: After installing the new brake cable, carefully reassemble any disassembled parts. Plug in the washing machine and test its functionality to verify that the brake mechanism engages and disengages as intended.
Hisense top loader WTCT802 8kg washing machine,
This could be down to a number of reasons. The most common of which is a displaced or faulty spin switch. This switch tell the machine that the lid is closed (or that the top is on a front loader). I know this may sound silly, but if you have a spin speed selector, double check to see that it's not been set to "0".
If neither of those work/fit the problem, and also if it is showing any error codes, eg. F01/F02/UNB, please let me know
My girbau washer flashing ALn error,how to fix it? thanks.
its should be that is the Inverter Drive error.
Check to see if the cooling fan is working on the inverter. If not, then when the drive gets hot, it will cut off in the high speed extract.
If the fan is working then it's probably an inverter.
IG IGNIS 105 LA washing machine does not show and light after a low voltage run and power surge. please guide where to look into. I am located at a remote area in Nigeria.
If your IG Ignis 105 LA washing machine does not show any lights after a low voltage run and power surge, check the power supply, main control board, and internal fuses for damage. Consider contacting IG Ignis customer support for remote troubleshooting guidance or arranging for a technician to inspect and repair the appliance.
Hi Tracey and welcome to JA, sorry for the delayed response, flat out all day here,,
The clicking sound you speak of, is it coming from the door latch/catch area of the cabinet,,
Can you lean down for me, seta wash program and listen very closly and pin point the origin of the clicking sound,,
It will either be near the door handle on the door, or behind the control panel ok,
Cheers.
How to reset the samsung wa7584c1 + control panel
my washing machine returns the 1E error and its not the pressure switch. when i bypass it works but wants to reset it. How do i operate the control panel to reset. please help
1.To reset the control panel of your Samsung WA7584C1 washing machine, you can follow these steps:
2.Unplug the washing machine from the power outlet.
3.Wait for a few minutes to ensure that any residual power is discharged from the machine.
4.Plug the washing machine back into the power outlet.
5.Press and hold the "Start/Pause" button for approximately 5 seconds.
6.Release the "Start/Pause" button once the control panel lights up or resets.
Check if the error code (1E) has been cleared.
If the above steps don't work, consult the user manual of your washing machine for specific instructions on how to reset the control panel or troubleshoot the 1E error code. If the issue persists, it may be necessary to contact Samsung customer support for further assistance or to schedule a service appointment.
What does the coues of E4 error on Aftron top loading washing machine error code?
When the E4 error appears on your Aftron top-load washer, it usually means there's an issue with how the lid closes or locks. This error prevents the washer from knowing if the lid is shut tightly during use.
* Ensure the lid is completely closed and latched. If it's not fully closed, the washer will not start.
* Inspect the lid lock for any damage or blockages (e.g., dirt, debris, faulty latch) as these can prevent the lid from locking.
* Power off the washing machine and unplug it briefly, reconnect the power and restart the machine, this reset may resolve the error.
* Use a multimeter to check if the lid switch has continuity, this test will determine if the switch is functioning properly.
