20 Most Recent
Johnson Minn Kota Mk 25 & Mk 35 On Board Maintainersstyle: Mk 35 Questions & Answers
Minn Kota mk25
Do you remove the trolling motor wires before charging..? ...If not.. try that......mine started taking a LONG time to charge.. after I remove the trolling motor cables.. it take less time and charges better!!!
Wiring diagram for a minn kota mk220 2 bank charger
First. the +/positive/hot wires go to the respective/separate +positive/hot side battery terminals.. and the -/negative/ground wire go to their respective/separate -/negative/ground battery terminals.
The wires from the charger are "paired out".. meaning the + and - pair must go to the same battery. .. you can't mix and match.
How to wire up 24v minn kota to batterys
if you are trying to wire the batteries for teh 24 volt motor then you need to connect the positive of one battery to the negative of the other battery. then connect the trolling motor to the remaining two terminal of the batteries.
if you are trying to connect the charger to the batteries then each battery should have its own set of wire coming from the charger.these wires should be connected to the batteries in a set not crossed between batteries.
I have a 1978 70 hp johnson with the spark plugs
Hi, with your spark plugs in you are turning the engine over against compression, thats why its harder to turn. The binding noise could be your piston rings, buts its difficult to say without further information. Sorry
I have a 1977 85 hp johnson outboard it started
i have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
