20 Most Recent Clymer Evinrude/Johnson 2-70 HP Two-Stroke Outboards Includes Jet Dri Questions & Answers
1990 Evinrude 40 HP with no fire on lower cylinder, how to fix
Need to know more... is it no spark? or is it no fire? -- first check spark with a spark checker or by pulling spark plug out and grounding the plug then cranking to see if it sparks... if it sparks check compression -- if you have spark and compression its most likely fuel and you need to do lower carburetor
3/23/2019 12:23:55 PM • Clymer... • Answered on Mar 23, 2019
2answers
Gas oil mix for 1990 evinrude 6hp
Mix 8 ounces of two cycle oil to one gallon of gas.
6/14/2017 12:20:10 AM • Clymer... • Answered on Jun 14, 2017
1983 9.9 evinrude runs good on land but will not accelerate under load
Possible wrong plugs, bad plugs, bad coil, bad wires, or any combination.
4/2/2017 7:07:14 PM • Clymer... • Answered on Apr 02, 2017
1983 9.9 evinrude runs good on land but will not accelerate under load.
This happened to mine, I found out the gas lines were going bad and restricting the flow of gas
4/2/2017 6:50:42 PM • Clymer... • Answered on Apr 02, 2017
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section Evinrude Johnson outboard parts Drawings How to videos 1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
7/3/2016 9:14:16 AM • Clymer... • Answered on Jul 03, 2016
How can you tell if motor is froze up
Hi Jeff, The link below is a short youtube video on how to fix a car that doesn't crank, I hope this helped......CHEERS
4/17/2016 10:21:04 PM • Clymer... • Answered on Apr 17, 2016
What year is serial #6902M-E12464 evinrude 6hp outboard
1969
2/17/2016 6:21:00 PM • Clymer... • Answered on Feb 17, 2016
2answers
Capacity in liters of gearbox Evinrude 4 HP
fill with gear lube
7/10/2015 7:05:52 PM • Clymer... • Answered on Jul 10, 2015
What Year, HP, and Model is my Evinrude Outboard Motor with Serial Number 10812
Try MFG website, or their customer service email. You may find fellow owners that have created an online "club" and they will have the information for you. It sounds like an early model. Wiki may have information about the complete series, similar to the details they usually have about cars.
4/11/2015 1:11:52 PM • Clymer... • Answered on Apr 11, 2015
Clymer Evinrude/Johnson 2-70 HP Two-Stroke Outboards Includes Jet Dri Logo
30 questions posted
Top Clymer Vacuums Experts
john h
Are you a Clymer Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Clymer Vacuums
  • Clymer Vacuums
Most Popular Question
size year e70 tlcca
  • Vacuums
