20 Most Recent Humminbird Piranhamax 220 Fishfinder Questions & Answers
My piranhamax 20 240 vertical pixels is not coming
HOW TO HOOK UP THE power
8/4/2016 5:29:34 PM • Humminbird... • Answered on Aug 04, 2016
0answers
0answers
0answers
When the unit is powered on, it goes on the
It ever well could be a transducer or a unit issue. I would contact customer service and see what they can work out for you.
2/7/2011 4:39:40 PM • Humminbird... • Answered on Feb 07, 2011
I have a fishin buddy
I would contact our customer service group and see if they can help you out. There number is 800-633-1468.
1/3/2011 2:02:30 PM • Humminbird... • Answered on Jan 03, 2011
Unit will not start up.
There should be an in-line fusible link on the power supply wire and it should be checked for a blown fuse. If there is no fuse protecting the head unit, it may have received a voltage spike internally and caused internal circuit damage, requiring replacement. What can be done is remove the head display unit and wire it (with a fuse link) to battery posts and see if it powers up. If the unit does not come on, then the head unit will need to be replaced.
12/4/2010 12:43:58 AM • Humminbird... • Answered on Dec 04, 2010
0answers
Hello
here is the link to a website that you can download install manual. it is free. it will ask for a survey, you can skip it. click here to go there.
11/5/2009 2:56:49 AM • Humminbird... • Answered on Nov 05, 2009
Cut cable between probe and viewer. Can cable be
In a pinch, probably. For long term, no. ther eason being that you cannot get a good enough connection on the jacketed cable to make the sounder work properly. That and the fact that there is alot of voltage running through the wire!
Best to replace it.
Mike
9/27/2009 5:22:42 AM • Humminbird... • Answered on Sep 27, 2009
Gain failure
If you are 'testing' the unit by holding the right button and pressing power, the pmax units really don’t work with the internal test. What you are seeing in the test is what th humminbird factory computer test used to test it. That is really not intended to be used outside of the plant. If it works fine in normal mode then I would say that the unit is fine.
Best of luck!
Mike
9/27/2009 5:21:12 AM • Humminbird... • Answered on Sep 27, 2009
Hi guys, i bought one a year ago, and just got it
Hi!
If your 220 is in portable configuration (runs on 8 'AA' batteries) make sure that the batteries are 1.5 volts and not 1.2 or 1.3 volts. (1.2V times 8 batteries is only 9.6V)
Also check the battery compartment as we see leakage from some batteries which corrodes the connector plates that the batteries hook up to.
One more thing...check to see that the power cord is plugged into the unit with the notch in the plug pointing UP. The rubber plug housing on the sounder allows the cord to be plugged in backwards if it's forced a litlle bit.
Best of luck!
Mike
9/27/2009 5:14:45 AM • Humminbird... • Answered on Sep 27, 2009
Go about getting operational anual for fish finder humminbird
I found what you are looking for. Go to: http://www.humminbird.com/support/FAQ.aspx?faqid=72
You can download the operating manual.
11/26/2008 7:08:42 AM • Humminbird... • Answered on Nov 26, 2008
Wires pulled out if my humminbird 143 transducer, is it repairable?
unfortunately, no.. Amazon has great prices on new ones.
10/17/2023 10:28:18 PM • Humminbird... • Answered on Oct 17, 2023
Humminbird Piranhamax 220 Fishfinder Logo
25 questions posted
Top Humminbird Boating Experts
Bill Eager
ADMIN Andrew
ADMIN Andrew
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
View Most Popular
Humminbird Boating
  • Humminbird Boating
Most Popular Question
unit will not start up
  • Boating
