20 Most Recent
GE Washer Filter Power Line WH12X10330 Corcom 16WGF1 F43338E Questions & Answers
GE washer wont wash and spin?
Is this a new machine? If so, then it may have a sensor that lets it know that you have a big enough load. Mine will only wash when I have a full load of laundry.
If you have had it for a while and it just quit, then you may have a broken belt. A third suggestion might be that your drain is clogged. Any of these could stop a front load machine from washing.
The numbers you gave were for the noise filter on the washer. Not sure if that would make any difference or not.
I have a vintage GE
The first problem is the time you will use a product of the very old time , and ask you not wonder what it mains happened in the interval between 1930 and 2016 maybe its not only the changeof 110V to 120 volts it is not much difference but far enough to worry and what the effect is on the heat dissipation of the heating element inside (the coffee must be too hot 90 and 95 degrees are normal all the cables and more parts of Should Be Replaced if it was not modifiedin all Those years, it Should Be modified, and it was modified there must be for shure a big wire resistor be Placed in serial to release to the high aC power on the heating element. and maybe many more parts. gaskets cables and more must Be Replaced iif not safety for all. preventinfo and usefull to a hot Become bitter tasting coffee temperature.
8/5/2016 3:47:52 PM •
GE Vacuums
Answered
on Aug 05, 2016
