20 Most Recent
Broan-NuTone K210A30 Kitchen Hood Questions & Answers
Hood slide controls
switches and slide control for speedlook integral from the circuit diagram.
it is worth while getting the printed circuit board out and looking to see if the track is blown. if so this can ofted be repaired by soldering wire links over the damaged part of the track
How do I remove broan QS1 fan blade
theres a round clip you have to pry off (its silver but first you remove the the cotter pin looking clip that just slides out)..took me a few to figure it out but its a pain to remove ..use a small flat screwdriver and you will get it off eventually..then when reinstalling you have to press it in while lifting the clip with again a small flat screwdriver.
How do I replace a fan in a Broan bathroom fan/light combo Model 164-K
I just replace the whole thing if it has attic access. Have an electrician do it if you are not confident of your skill. Having the light work is not very helpful if the unit is shot. Clean and lubricate the fan shaft on your new one once a year and it will last a long time. You may be able to swap out just the fan if unplugs and it is not riveted in but you will have about the same time and money into it as replacement.
Leaking water
are you sure its water...does it have oil collector along filter...
or check for leakage from something from upper floor may be you have washroom or plumbing leakage
