20 Most Recent Protech Rheem/62-24084-82-1PK - Integrated Furnace Control Board IFC Questions & Answers
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES POWER LED - GREEN ON - Normal OFF - No power to board OK LED - GREEN One Blink - One hour retry delay Two Blinks - Pressure switch failure (remains open) Three Blinks - Limit switch fault Four Blinks - Pressure switch failure (remains closed) Five Blinks - Twinning fault FLAME LED - YELLOW ON - Good flame Rapid Blink - Flame present with gas valve de-energizing Slow Blink - Marginal flame
1/19/2014 6:13:31 AM • Protech... • Answered on Jan 19, 2014
Rheem 41vr40
Did you try amazon.com? they seem to have virtually everything, or at least a link to what you need.
11/28/2013 5:43:07 AM • Protech Water... • Answered on Nov 28, 2013
0answers
Rheem 41vr40
Be the first to answer 11/28/2013 3:47:00 AM • Protech Water... • Posted on Nov 28, 2013Be the first to answer
Where can I get a Service Manual including error codes, of HITACHI Package unit RUA-30AT3S?
I am not sure they are available to non Hitachi service centres. https://documentation.hitachiaircon.com/glb/en/pac/rua-at3s
3/17/2024 4:06:16 PM • Water Heaters • Answered on Mar 17, 2024
VAILLANT ECOTEC PLUS 831 BOILER , with an error code of F79, which is not in the handbook, its not working at the moment, already had a local plumber out, who didn't know a lot about F79 code
Cannot find the fault code . There are vidoes on u tube saying how to reset thr code By pressing the reset button . If this does not work youcan ccontact vaillent on there web page . I have a mate who works for them i will ask him as well
2/12/2024 9:14:32 PM • Water Heaters • Answered on Feb 12, 2024
2answers
Envirotemp water heater
Do I need to insulate this heater out in the shed? Freezing temperatures
2/6/2024 11:45:03 AM • Water Heaters • Answered on Feb 06, 2024
Remeha avanta plus combi problem
Call a engineer
1/11/2024 7:52:09 PM • Water Heaters • Answered on Jan 11, 2024
What is error code c8 mitsubish heater
The P8 fault can mean many things when it pops up on your Mitsubishi Electric wall controller. The P8 fault is activated when the indoor coil sensor does not change the temperature for a set amount of time after the compressor is (or should be) switched on.
12/26/2023 4:41:20 PM • Water Heaters • Answered on Dec 26, 2023
How to replace digital thermostat on Amtrol boilermate to a manual thermostat
Where does the tube sensor go
12/23/2023 12:54:29 AM • Water Heaters • Answered on Dec 23, 2023
10 year old Richmond 40 Gallon water heater, cannot move knob to ON/OFF or Pilot. Pilot light is out.
call plumber to replace gas valve, it may cheaper replace water heater. gas valve is not DIY
12/1/2023 6:48:46 PM • Water Heaters • Answered on Dec 01, 2023
My boiler doesn,t always switch off when programe is off
test for sticking relay faulty circuit board or faulty stat
10/28/2023 4:42:20 PM • Water Heaters • Answered on Oct 28, 2023
Rival titan floor heater coils don't turn red
Beware when working with electrical equipment. It may cause electric shock. Check the power supply wires, connections with heating coils. If they are ok then possibly heating coils require replacement.
10/17/2023 2:53:24 PM • Water Heaters • Answered on Oct 17, 2023
3answers
Where on a sunday do I find a GS640YBVIT heater?
I would try their website; www.statewaterheaters.com They should show a list of their service agents.
8/28/2023 6:22:14 PM • Water Heaters • Answered on Aug 28, 2023
How do I bleed the pump? It's running but not circulating water after partially draining the hot water heater.
Domestic Central Heating, Dodge Caravan, well pump or a Pool Heater, or something else. All questions need 'make model (what it is)' as first 3 words. With the exception of the Dodge Caravan, pumps have a small bleed screw. Google make model bleed pump or if it is an above ground well pump make model prime pump This is heavily weighted towards vehicles, but you will get the ideal of the power of Google! https://www.google.com/search?q=%E2%80%8Bmake+model+bleed+water+pump ..
5/17/2023 10:56:35 PM • Water Heaters • Answered on May 17, 2023
Towerchron QE2. Timer set up ok. Room thermostat set 25. Timer lights ok at set timings. Boiler will not come on
Call for Service. The timer is fine, the boiler has failed. I presume it is gas fired, which means that only gas registered service techs can work on it.
4/16/2023 10:15:58 PM • Water Heaters • Answered on Apr 16, 2023
Energy smart water heater has start up failure
Energy smart water heater has start up failure problem so how to resolve
3/26/2023 5:11:27 PM • Water Heaters • Answered on Mar 26, 2023
Protech Rheem/62-24084-82-1PK - Integrated Furnace Control Board IFC Logo
1 questions posted
Top Protech Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Protech Water Heater Expert? Answer questions, earn points and help others
View Most Popular
  • Protech Water Heaters
Most Popular Question
protech 62 24084 02 troubleshooting
  • Water Heaters
