20 Most Recent Microsoft Windows Vista Home Premium for PC Questions & Answers
To play the avi files. you can try to options.
1. You can download a different media player which is VLC media player. It plays almost all kinds of video format.
2. Download K-lite codec and run it and you should be able to play .avi files in media player.
Hope it helps :-)
Microsoft... | Answered on Nov 08, 2019
This was caused by Microsoft Office 2010 Beta version which was based on Application Virtualization.
Microsoft... | Answered on Mar 17, 2012
That depends on Operating system, if it is in vista please repair the OS it will get reset...
If it is in XP follow below steps
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
Hope you will succeed...
Microsoft... | Answered on Oct 29, 2011
Use reginout regcleaner it will fix ur problem
Microsoft... | Answered on Aug 31, 2010
u can remove from any of antivirus software just open that software and scan your full system it will detact your virus then try to repare with that software
hope fully u will able to remove your virus
Microsoft... | Answered on May 13, 2010
You have to install Seagate software for that then you can restore your data back to windows 7.
Microsoft... | Answered on Mar 29, 2010
Your talking about your desktop background right? Take a screen shot by hitting the prtscreen button on your keyboard. There is a tutorial that goes into detail here http://ask-leo.com/whats_a_screen_shot_and_how_do_i_make_one.html
Microsoft... | Answered on Sep 22, 2009
Download the latest version of flash player here and try to install.
Microsoft... | Answered on Sep 20, 2009
Yes that computer specs that you have will work with a game running Windows Vista , but if you want to have a great gaming experience with Vista better if you use a 2 gig of RAM and at least 256MB of video card....
Microsoft... | Answered on Aug 25, 2009
this can be due to two reasons.
first if you are trying to sign in ... it is possible that someone has logged on with you id so yahoo is denying another logon attempt. sometimes trying to log on when yahoo messenger is also logged in at the same time gives this error message. seleting temporary internet files can also help.
otherwise if this message comes up when trying to make a new yahoo id .. it simply means it is taken by someone else so try some other id.
Microsoft... | Answered on Aug 08, 2009
The operational system is established not correctly or the hard disk is damaged
See here:http://windowsinstal.977mb.com/map.html
Microsoft... | Answered on Jul 26, 2009
try reinstalling windwos that usaullt helps
Microsoft... | Answered on Jul 20, 2009
You can download hackingtosh but its a bit illegal and not that I wouls suggest it. But Ubuntu also looks like a mac if you install the mods, you may want to try that.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Microsoft... | Answered on Jul 19, 2009
You must activate your copy of Windows. Good old Micro$soft has Vista connect to the internet and automatically check to see if you have registered your copy. Since you had to reinstall, it now thinks you have a duplicate (and illegal) copy. So now you'll have to spend an hour or so on the phone to get another key.
Microsoft is the only place to get product keys for Microsoft products.
Microsoft... | Answered on Mar 31, 2009
How to Turn Keyboard Lighting On / Off Tulie Finley-Moise
June 28, 2019
Laptop keyboard lighting has changed the computing game and has made space for nighttime users to power on through the darkness. The vast majority of modern laptop computers come with backlit keyboards in addition to boasting a number of other fancy features that may distract from this rather basic, but wholly necessary feature.
So, you've got a new computer and you're not quite used to the many shortcuts that allow you to change certain settings with the simple click of a button. When the sun goes down and you've still got hours of work to go, you'll want to know how to turn on keyboard lighting so you can soldier on through the night.
Let's break down how to make your PC work for you, delving into how to turn on your keyboard light, how to turn off your keyboard light, and the fixes to some troubleshooting errors you may run into with your HP laptop.
How to turn on a backlit keyboard? If your HP notebook computer has a backlit keyboard, take a look at the top bar of your keyboard and locate the F5 button. This button may even be labeled with a backlight icon. Simply clicking this button while pressing the Fn button located at the bottom row of your keyboard will leave you with keyboard lighting operational magic.
It may be a simple on/off or, on some models, you can adjust the brightness of the backlighting.
Also, depending on your computer model, your PC may be configured to control the backlit keyboard via the F9 or F11 button rather than the F5 button. Practice the same simultaneous Fn + F11 operation to turn on a backlight keyboard light.
How to turn off a backlit keyboard? Once morning hits and the natural sunshine illuminates your keyboard, you may find you have no need for the keyboard light to be on. In order to turn off the backlight on your laptop keyboard, press the same corresponding keys that allowed you to turn them on.
This could be a simple F5, F9, or F11 key press, or a dual-action Fn + F5, F9, or F11 key press.
How to adjust brightness on a backlit keyboard? Your productivity depends on a number of particular elements that can make or break your flow. Sometimes it's the brightness of your screen or your keyboard that can throw you off or exhaust your sensitive retinas.
In order to adjust the brightness on your keyboard backlights, press the backlight function key a couple of times for a dimmer illumination. This button alone functions as your one-stop-shop for all keyboard light operations.
How to change the color of a backlit keyboard? Gamers saddled up for leaderboard success with an HP OMEN laptop have the option to toy with the color of their backlights as well. It's no secret that gaming laptops often come with funky backlight features that add a certain edge to any competitor's spirit.
Zoned backlighting
HP OMEN laptops feature zoned backlighting that enables users to assign and modify different backlight colors to specific keys and keyboard zones. Gamers use a number of keys to explore, attack, and strategize, so having visual segmentation helps simplify the interface for optimized precision.
For example, a PC gamer might want to assign red backlight colors to movement keys (WASD keys and arrow keys) and assign a blue light to item keys. The user will be able to hit each key with confidence, even if their eyes aren't zeroed in on the keyboard.
In order to change the color of a backlit HP OMEN laptop keyboard, follow these six steps:
  1. Open OMEN Command Center from your Windows taskbar or via the Windows Start menu
  2. Select "Lighting" located on the left navigation sidebar
  3. At the top-right corner, make sure you select "Keyboard." You will see three available modes: Animation, Static, and Off
  4. Select "Static" to manually assign specific colors to specific areas of the keyboard. The "Template" dropdown menu will reveal six different preloaded templates and a "Custom" option that allows you to design your own keyboard segmentation. These pre-existing templates will include WASD, FPS, MOBA, MMO, P1-P6, and All Keys
  5. After selecting a template, you will see a color guide at the bottom of the OMEN Command Center that will allow you to assign colors on the basic guide of advanced color options of your own selection
  6. Press "Apply" and marvel at your colorful keyboard setup!
How can I animate my HP OMEN backlit keyboard? One of the coolest features integrated into HP OMEN laptops is their capacity for keyboard light animation. Designed to give gamers a more immersive experience, HP OMEN laptops can be configured to brighten and pulse with the bass and treble within your PC. So whether you're the shooter ready to aim and fire, or the victim of a fatal game-changing blow, your keyboard will come to life with your game scape.
In order to animate the colors of your backlit HP OMEN laptop, follow these seven steps:
  1. Open OMEN Command Center from your Windows taskbar or via Windows Start menu
  3. At the top-right corner, make sure you select the keyboard
  4. Select "Animation" under "Mode" to assign specific color-shows to the keyboard
  5. The "Effect" dropdown menu will reveal nine different preloaded animation settings that allow you to design your own keyboard segmentation
    1. These pre-existing animations include Color Cycle, Starlight, Breathing, Ghosting, Ripple, Wave, OMEN X, Raindrop, and Audio Pulse
  6. After selecting an effect, you will see a color scheme guide at the bottom of the HP OMEN Command Center.
    1. Pre-loaded animation themes include OMEN Galaxy, OMEN Volcano, OMEN Jungle, and OMEN Ocean
    2. You can also create your own color scheme by choosing "Custom"
    3. Modify the speed and direction of the animation with the sliders located at the bottom right
  7. Preview your animation creation and press "Apply" to implement changes
Can I install a backlit keyboard on my laptop? If your computer does not come with an integrated backlit keyboard it'll be incredibly difficult, perhaps even impossible, to install one unless you're a seasoned computer engineer. Integrating a backlit keyboard is not as simple as mere installation; there are a number of components and programming procedures that must be taken into account as well.
Unlike their bigger desktop sibling, laptops are smaller, slimmer, and more intricate due to their compact nature. That means that they're generally more difficult to take apart and reassemble. For inexperienced non-professionals, getting underneath the keyboard plate without proper training or proper tools may do more harm to your PC than anything else.
If you're looking to upgrade your laptop to a high-tech backlit keyboard laptop, HP has a number of exceptional options for all types of PC users.
What are the best HP laptops with backlit keyboards?
For casual users: HP ENVY x360 13z touch laptop
Versatile, capable, and supremely portable, the HP ENVY x360 is the casual PC user's ideal companion. The 13.3-inch touch display delivers beautiful AMD Radeon™ Vega 3 Graphics and impressive processing speed with the integrated AMD Ryzen™ 3 processor. From movie-watching to website creation, this laptop is perfect for the casual user, day or night.
For professionals: HP ZBook 15V G5 mobile workstation
Whether you're stationed in an office cubicle or you're out travel blogging for a living, the busy professional in you needs an adequate computing partner in order to keep up with your demanding workload.
The HP ZBook 15V G5 mobile workstation goes above and beyond when it comes to blazing performance speed and long-lasting durability. The full-sized, spill-resistant backlit keyboard ensures you can power on even under messy conditions.
For gamers: HP OMEN 15-inch laptop
Built from the ground up with powerful processing, next-level graphics, and future-proof gaming in mind, HP OMEN computers are engineered for gaming success. The HP OMEN 15-inch laptop boasts sprawling, immersive game scapes and high-powered gameplay with a hexa-core 8th Generation Intel® Core™ i7 processor supported by a NVIDIA® GeForce® GTX 1070 dedicated graphics card.
The built-in, full-size, 4-zone keyboard features NKRO anti-ghosting key technology. That means you can press as many keys as you need to win your battle royale round without ever losing a keystroke.
What are the best external backlit HP keyboards?
HP OMEN Sequencer keyboard
Characterized by individually backlit keys, the HP OMEN Sequencer keyboard is top of its class. Offering up to 16.8 million RGB colors to choose from, this backlit keyboard is even capable of handling unique effects, all customizable within the HP OMEN Command Center.
Made for gaming, this optical keyboard allows you to strike with lightning speed, enabling a remarkable 0.2 ms response time. That's 10 times faster than traditional mechanical switches!
HP Elite x2 1013 G3 collaboration keyboard
Tablets are fantastic; compact, portable, and super sleek. But when it's time to crack down on your workload, you may find it difficult to do so without a keyboard. Enter the HP Elite x2 1013 G3 collaboration keyboard. This backlit keyboard helps bring your tablet creations and documents to life without sacrificing any of the razor-thin portability you love.
HP OMEN keyboard 1100
Nothing says gaming keyboard like a keyboard with the WASD keys pre-highlighted. Never miss another shot with the HP OMEN keyboard 1100. This backlit beauty comes equipped with impressive anti-ghosting technology and ultra-responsive blue mechanical switches to fine-tune your response time.
About the Author: Tulie Finley-Moise is a contributing writer for HP® Tech Takes. Tulie is a digital content creation specialist based in San Diego, California with a passion for the latest tech and digital media news.
Microsoft... | Answered on Jan 31, 2020
a hand held still camera..
to DO WHAt>? Download photos or ??????????
well you need good USB cabled to do that
and try all USB ports on the unstated PC.
or or ask Samsung for drivers need for ST66, it is there cam.
Microsoft... | Answered on Jan 18, 2020
YOU BUY THE PROGRAM OF COURSE
Microsoft... | Answered on Jan 14, 2020
Microsoft Windows Vista Home Premium for PC Logo
14 questions posted
Top Microsoft Computers & Internet Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Scoee Scoffer
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
copy windows not valid
  • Computers & Internet
