20 Most Recent Oxo Good Grips 11-pound Digital Kitchen Scale with Pull-Out Display Questions & Answers
Sounds as though the LCD display is faulty and only half is lighting up. I would have thought the cost of replacement is greater than the scales are worth. May be a bad connection that needs resoldering, but usually they are not serviceable.
Oxo Good Grips... | Answered on Aug 04, 2015
I am having the same problem with the 5lb scale. Turned it on for the first time about 5 days ago and was ok. This morning when I went to use it it gave the ErH code. Would appreciate if any person has an answer. I am waiting for OXO to respond my e-mail.
Oxo Good Grips... | Answered on Jan 03, 2015
I just started 6 weeks ago and I've gotten 2 check for a total of $2,200...this is the best decision I made in a long time! "Thank you for giving me this extraordinary opportunity to make extra money from home. This extra cash has changed my life in so many ways, thank you!"
Visit site: http://nEWAY.com
Dishwashers | Answered on Feb 10, 2020
unplug it overnight to reset it. If that doesn't work, you probably need a new board.
Dishwashers | Answered on Feb 04, 2020
EVER WANT TO KNOW THE MAKE OF SOMETHING ?? WE CAN NOT ASSIST WITHOUT KNOWING IT
TRY ASKING THE MANUFACTURER
Dishwashers | Answered on Jan 31, 2020
Hello. From what you describe, the detergent dispenser has become defective and needs to be replaced. Normally, if run daily, you should get a week's worth of washings before needing to fill the compartment. Make sure, if there is a setting dial(with an arrow) inside the rinse aid compartment, that the arrow should be at 2 1/2 to 3, give or take a little. You don't want too much rinse aid in the water as it can cause a severe foaming of the water which can trigger a drain error--the unit thinks its draining water when, in fact, its sensing foam and stays on too long. The main board senses this and triggers a shutdown for safety. Washing machines can experience this same phenomenon from too much detergent--its called a SUD error, for too much suds in the water.
Dishwashers | Answered on Jan 23, 2020
Oxo Good Grips 11-pound Digital Kitchen Scale with Pull-Out Display Logo
10 questions posted
Top Oxo Good Grips Dishwashers Experts
Marvin
Marvin
Are you an Oxo Good Grips Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Oxo Good Grips Dishwashers
Most Popular Question
numbers oxo digital food scale appear
  • Dishwashers
