20 Most Recent Frigidaire 16.7 cu. ft. Freezerless Refrigerator FRU17B2J Questions & Answers
May be just the thermostat or the start capacitor on the compressor. Still cheaper that buying a new one.
Frigidaire 16.7... | Answered on Aug 17, 2016
sound like the condenser fan motor by the compressor has stopped and the not allowing the proper cooling check that also you should have waited at least 6 hr upright before starting the unit
Frigidaire... | Answered on Oct 23, 2019
call a repair service or go buy a new one
it is actually 'Sb', you are in Jewish Sabbath mode which prevents anything being turned on or off on a Saturday.
The display shows "Sb" or "5b" while in Sabbath mode.
SB Sabbath Mode
The Sabbath Mode is a feature that disables portions of the fridge and its controls in accordance with observance of the Sabbath and religious holidays within the Orthodox Jewish community. Sabbath Mode is turned ON and OFF by pressing and holding "?" on freezer temp and "?" on refrigerator temp for five seconds.
In the Sabbath Mode, the High Temp alarm is active for health reasons. If a high temperature alarm is activated during this time, due to a door left ajar, the alarm will sound for about 10 minutes. The alarm will then silence on its own and a red high temperature icon will display. The high temp icon will continue to display, even if the door is closed, until the Sabbath mode is exited and the icon reset. The refrigerator will function normally once the door is closed, without any violation of the Sabbath/Holidays.
https://www.google.com/search?q=Error+code+56+on+Frigidaire+upright+freezer
Here is a list of all the error codes.
Frigidaire Refrigerator Error Codes Fault Codes
Frigidaire... | Answered on Aug 01, 2019
Always at least and inch or two away from wall.
consult your installation instructions or use guide for info
Frigidaire... | Answered on Jun 24, 2019
The temperature control is located inside the freezer on upright models, and onthe left outside wall on chest models. The temperature is factory preset to providesatisfactory food storage temperatures.
However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If acolder temperature is desired, turn the temperature control knob toward COLD-EST and allow several hours for temperatures to stabilize between adjustments
Frigidaire... | Answered on Jun 16, 2019
Freezers expel warm air. There should be no 'blowing' inside. If it is expelling warm air, then it is working fine, eventually the expelled air should get cooler and cooler.
Frigidaire... | Answered on Jun 06, 2019
That yellow light on sonne older modelks is just showingbtge power is on. I never heard of a chest freezer having a "quick freeze" feature. This feature would also require forced air cooling and auto defrost. If the walls get frost on ghr m t hen Im betting that is ju st a power light although it may say freeze or something else like that. Its just so when you see the yrllow light you know there is power.
Frigidaire... | Answered on May 20, 2019
Typically, error code "HI" (the customer may say "H1") on a Frigidaire refrigeratorunit indicates that the unit has detected high temperature in the freezer and/or therefrigerator https://kb3.s2g.net/index.php?/article/AA-00411/0/Frigidaire-Refrigerator-Unit-Flashing-HI.html
Frigidaire... | Answered on Mar 29, 2019
Many reasons why it may be loosing temperature. Such as Defrost problem, fan not running, sealed system problem, compressor problem
Frigidaire... | Answered on Jan 18, 2019
Frigidaire 16.7 cu. ft. Freezerless Refrigerator FRU17B2J Logo
1 questions posted
Top Frigidaire Freezers Experts
John Tripp
John Tripp
Dennis Boxerman
Bruce Denton
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
fan runs all time but doesnt blow cold
  • Freezers
