Hello Debby Rhodig, thank you for your post!
Based off the information for your Frigidaire refrigerator I see that your fresh food side is not cooling and the alarm is going off. I would check to verify there is no food or packages blocking the rear vent. If there is nothing blocking the vent place your hand back there to check if you feel any cold air coming out of the damper. If there is no cold air coming out of the damper it could be an issue within your evaporator fan, if there is cold air coming out I would set your temperature to a colder setting. Changing the temperature inside your appliance can take up to 24 hours to stabilize. If you continue having issues with your refrigerator I would seek assistance from a professional to come out and properly diagnose and repair your appliance. I hope this helps. -Matt
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
8 questions posted
322 Questions
159 Questions
143 Questions
42 Questions
