20 Most Recent Maytag 21.1 Cu. Ft. White Refrigerator - M1BXXGMYW Questions & Answers
There are only a few scenarios where the water is coming from to freeze there.
Condensation from putting food in there which is warm, especially anything not wrapped or bagged.
Defrost water drain blocked. Look for a channel at the back or within the blower unit.
Badly fitting, split or worn out door seal. This lets warm moist air from the room into the cabinet which then freezes.
Excessive frost build up reducing efficient circulation of air, or overloading.
Finally, kids spilling water!
Maytag Freezers | Answered on Jul 08, 2019
thermostats are usually a "on/off" switch just as a simple light switch. Ohms on a defrost timer is not very specific. It is basically a switch that turns heaters on and off while keeping the compressor off during the defrost cycle. Your thermostat may be sticking/hanging up.
Maytag Freezers | Answered on Aug 11, 2017
I have had a few of these, and others of the same ilk.
Your problem should be air leakage into the machine.
Take a thicker piece of paper, not cardboard, and try to slide it around the gasket where the door gasket contacts the front of the freezer.
The gasket should be firm enough to prevent the paper from sliding. Wherever you can move the paper, you could have a air leak.
Most of these have no adjustment in the latch to tighten the door. Sometimes a new gasket will solve the problem, sometime a new door will.
P.S. Twice I have tied a new freezer to a refrigerator dolly to move it and have accidentally warped the door, and they cannot be straightened. :-(
God bless your efforts.
Maytag Freezers | Answered on Jul 07, 2017
repairs should be performed by a qualified technician. if there isn't ice in the ice bucket located in the freezer you have a water flow problem. if there is water going to the filter and nothing out of the freezer then you have a clogged freezer replace it. if these things are ok then yes it could be the electronic control. filter failure is a common problem.
Maytag Freezers | Answered on May 02, 2017
thermostat
Maytag Freezers | Answered on Mar 10, 2014
if you are talking about the bucket the cubes go into, most likely you do not use a lot of ice. the ice isn't melting, it's evaporating. usually winds up in a big clump at the bottom.
Maytag Freezers | Answered on Nov 06, 2013
Maytag 21.1 Cu. Ft. White Refrigerator - M1BXXGMYW Logo
0 questions posted
Top Maytag Freezers Experts
John Tripp
John Tripp
Ismael Rodriguez...
Dennis Boxerman
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
View Most Popular
Maytag Freezers
  • Maytag Freezers
Most Popular Question
am looking defrost timer maytag upright
  • Freezers
