20 Most Recent Sub-Zero Sub Zero Freezer Door Gasket 7010572 Questions & Answers
2answers
Sub zero side by side door won't open till about
When you open the door and then close it they will cause a vacuum. some freezers have a pressure relief. if the heater stops working on the relief it will cause this.
1/29/2015 7:15:08 AM • Sub-Zero... • Answered on Jan 29, 2015
What can I do to get the ice cream to be frozen?
It might be a good idea to clean the condeser coil. If the coil is blocked, your freezer will not get cold enough.
6/3/2014 4:34:58 AM • Sub-Zero... • Answered on Jun 03, 2014
0answers
My freezer in my sub
clean the radiator and check the freon.
11/15/2013 7:39:02 AM • Sub-Zero... • Answered on Nov 15, 2013
Convert r-12 to r134a
if the compressor is r12 and want to use it with 134a you need to change the oil in the compressor before you do the change, and while you change if make sure that he 1st 50oz of gas you charge it with the compressor off. its recommended r12 because it works better at high temperature.
11/15/2013 7:16:28 AM • Sub-Zero... • Answered on Nov 15, 2013
Clogged ice maker
1, ice maker may need to be replace, 2 water line may be frozen , if so turn off the freezer to defrost it for few hours, 3. when was the last time to replace the water filter? make sure you replace it when the time expired.
11/15/2013 6:55:53 AM • Sub-Zero... • Answered on Nov 15, 2013
Sub zero freezer - 501 f
It is likely the condenser fan is not functioning. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
10/23/2013 3:58:27 AM • Sub-Zero... • Answered on Oct 23, 2013
I have a Sub-Zero 501 F upright freezer. I have
sounds like the mullion heater (drain tube heater is open). take back off (after removing all shelves, including the glass tray (remove 4 screws). Pull back out, careful not to pull wires off T'stat. Run the new wires on heater behind evaperator, placing heater down in drain hole. Good LuckJoe
9/10/2013 12:46:38 AM • Sub-Zero... • Answered on Sep 10, 2013
0answers
Freezer coil inside freezer box
There are three parts to all defrost systems. 1. Defrost Heater2. Defrost Timer3. Defrost ThermostatWithout a model number I could not look up a diagram or part numbers. I very seldom see a bad heating element. Most common is a bad defrost timer, second most common is the defrost thermostat.
8/3/2011 1:01:43 AM • Sub-Zero... • Answered on Aug 03, 2011
Freezer not getting below )
The condenser is the 'radiator' located under the unit near the compressor. If it's clogged it will cause this. Make sure, also, that the fan at the condenser is operating.
If you've not yet cleaned the condenser, do so with a vacuum both sucking, and then blowing, to clean it well. BE READY FOR A DUSTY MESS!!
6/18/2011 11:12:47 PM • Sub-Zero... • Answered on Jun 18, 2011
Freezer doesn't cool but refrigerator
Check the relay on the freezer compressor. It may be shot.
themobilian_2153.jpg If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
4/16/2011 12:45:29 AM • Sub-Zero... • Answered on Apr 16, 2011
Our sub zero refrigerator compressor
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
2/6/2011 3:17:19 AM • Sub-Zero... • Answered on Feb 06, 2011
Freezer door "locks" or is
This is normal. Freezers have a vent port to let high moisture out. When you open the door moisture laden air enters. When the door is closed the hot air from outside expands and leaves through the vent port. This creates a vacuum in the freezer that lasts a few minutes. No problem
9/16/2010 4:48:37 PM • Sub-Zero... • Answered on Sep 16, 2010
The temperature is going up.
dear sir / madam '
i think he has make new temperature setting so please turn on your temperature satting nobe to minimum point and check freezer,s compressor is working , i hope it will work again if not then possible there is any electrical problem possible or leakage in the copper pipe then try to contact to maintenance personnel for further action.
hope answer the question
thank you
please vote!
9/14/2010 4:26:39 PM • Sub-Zero... • Answered on Sep 14, 2010
My model number 2811 has
Diagrams here : http://www.searspartsdirect.com/partsdirect/part-model/Sub-zero-Parts/Refrigerator-Parts/Model-2811/3054/0161000?searchedModel=2811&blt=05
These are the best I can Do with the Diagrams but I can explane what is going on, and possible soloutions.
Your defrost drain is mostlikeley frozen. This is located on the right hand side, just inside the metal cover. When you remove the meteal cover (((evaperator cover or water pan))) you will see the hole on the right.
Since this is cloged then the water stays in the cover or pan and freezes after the defost cycle.
after you remove the cover you will see the evaperator (( aluminum tubing with fins))) and the heater ((( Black Rod )))
When your machine gose into defrost about every 8 hrs, this heater melts the ice off the evaperator((( Hence Frost Free ))) and the water goest into the (((( evaperator cover or pan ))) and flows to the defrost drain hole to a pan under the machine.
They make a after market heater for the drain... it is a pain to install.
First I would try to defrost the drain by poring war water down it and verifying it goes into the pan at the bottome of the machine.
When your done you will need to silicone around the (((cover / pan))) where it covers the defrost drain hole.
Good Luck
Don
Mr Fix it
9/8/2010 4:27:03 PM • Sub-Zero... • Answered on Sep 08, 2010
Our sub zero seems to
The defrost may be lasting too long....and ice cream is always the first thing to melt... you need at least 10 F to keep ice cream hard...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
9/8/2010 4:05:46 AM • Sub-Zero... • Answered on Sep 08, 2010
I have a sub-zero 642
When they replaced the evaporator coil they had to re-charge the unit. Sounds like there may be a small leak.
8/23/2010 12:21:19 AM • Sub-Zero... • Answered on Aug 23, 2010
Sub-Zero Sub Zero Freezer Door Gasket 7010572 Logo
1 questions posted
Top Sub-Zero Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Sub-Zero Freezer Expert? Answer questions, earn points and help others
View Most Popular
Sub-Zero Freezers
  • Sub-Zero Freezers
Most Popular Question
get ice cream frozen
  • Freezers
