20 Most Recent
Sony Walkman NWZ-A826 Digital Media Player Questions & Answers
How to download a song from youtube to cellphone
Step 1: Download a third party program to record internal audio directly, because native recorder can only record audio from outer devices like microphones or headphones.
Step 2: Launch the program then hit "start" button. Play the video at the same time.
Step 3: After video finishes, hit the button again to stop recording.
Step 4: Edit music tags like artist, name, album, cover, etc.
Here are 4 tools for recording YouTube music in detailed steps: https://www.leawo.org/tutorial/recording-music-from-youtube.html?qa=1409
No Power Cables
some units you can do depending on the quality of the unit as you can use a samsung charger on a xperia
best way to know for sure is to take it into a shop and ask to check to make sure it works
if it was me i would try the different charger doesnt matter what kind it is.
Doesnt work
If you did Not Drop it and Pressing the Reset button on the back does not fix it. Then there is a possible short in the wiring inside, The Sony Walkman has had some issues of late with Quality control.
Try pressing on the back panel with your 2 thumbs where the LCD and Button Controls meet. If you can get the power to turn on with the pressure between to two then there is a short that can be fixed. If you have the ability to open the Sony and do your own soldering. If you can not do that then you need a Sony Tech to open it and re-solder the wire that has come loose and is causing the short
If that option does not work and if you no longer have warranty coverage you have a couple of options recycle it or throw it away and buy a new one. Or you can take it to a local Sony store and have them mail it to Sony. For this service you will have to pay 30 dollars for parts and labour to have them mail it in to Sony where Sony will ship you back a refurbished unit.
The odds of you getting the same unit back are against you. You may get a refurbished unit as a replacement and that Refurbished unit may not even be the same colour as the unit you sent in for repairs.
The refurbished Unit will probably be the Same model # as long as it is a unit they are still producing, if not then you may end up having to paying an additional fee for them to upgrade the refurbished replacement to a model they are producing.
If you still have warranty coverage all you will need to do is pay the shipping and handling. Sony will replace the unit for free and may even upgrade you for free to there newest model if yours is a unit they are no longer producing. So for the Cost of having the item shipped to Sony you can get a brand new refurb unit
Good Luck
How do i delete unwanted
To delete songs just plug it into your pc and the folder containing your songs will open. To delete the songs you no longer want hover over them and right click and delete.
To create playlists on your player with MediaMonkey (MM), you have to first create your playlists in MM and then tell MM to sync them to your player. To do this you have to do the following:
1 On the menu bar click on "Tools" > "Options" and then "Portable/Audio Devices" on the side list.
2 Select your player from the "Available Devices" list and then click on the "Configure" button.
3 Click on the "Auto-Sync list" tab and then the "Playlists" tab and a list of your playlists will appear. Click on the playlists you want synced to your player. When you sync your player, the playlists (and the files they contain) will be loaded on your player. The playlists will be placed in a folder called "Playlists".
How to turn off nwz-a826
To turn the portable player on, press the Play/Pause button until the screen appears. To turn the portable player off, press and hold the Play/Pause button until POWER OFF appears.
To save the battery consumption, the player will do the following:
After turning on the power, if there is no operation or playback performed for about 1 minute, the power of the player turns off.
If there is no operation for a certain period of time while in stop mode, the display turns off automatically and the player enters standby status. If there is no operation for the next 30 minutes, the power of the player turns off.
When I go to listen to my mp4, it says
I started to have the same problem today and was also getting a "Library Error Encountered...." message. I was able to resolve it by Formatting my player. I lost all my data and settings but now I can put music on it again. To format your player go to the Home menu-Settings-Common Settings-Format
How does the bluetooth work?
well bluetooth is the new way to send information from device to device without wires or computer. When bluetooth is enabled on your walkman you can use something like your phone and turn the bluetooth on there and then transfer files to eachother, but you can also get wireless headsets, and you can use them wire free with bluetooth
Sony Walkman NWZ-E438F connects & disconnects itself from USB
I suggest that you uninstall and reinstall the USB Driver to resolve the issue.
Follow these steps to uninstall the driver and confirm the player is recognized
properly.
IMPORTANT:
- This procedure must be performed while logged in as Administrator or to an
account with Administrator rights.
- If you are using the Windows® XP operating system, you must have Service
Pack 2 or later installed.
- Click Start and then click Control Panel .
- In the Control Panel window, click Performance and Maintenance .
- In the Performance and Maintenance window, click
System .
- In the System Properties window, click the Hardware tab.
- On the Hardware tab, under Device Manager , click the Device
Manager button.
- In the Device Manager window, click the plus (+) sign in front of Disk drives
- Click to select the Sony USB device .
- From the menu, click Action and then click Uninstall .
- In the Confirm Device Removal box, click OK .
- Disconnect the portable player from the computer.
- In the System Settings Change box, click Yes.
After that, restart the computer and reconnect the Player to resolve the issue. USB Drivers are generic to the Operating System and will reinstall automatically after restarting the computer. I hope it works.
'Format not supported'
Hey.
I've just bought it and had a similar problem. What helped is:
1) Download Total Video Converter
2) In conversion format menu go to "Pocket Player."
3) Click "SONY Cellphone" and choose the middle line (Sony K700... blah blah)
4) Set the quality on "normal"
5) Low quality won't work - it'll say the file's not supported.
6) This worked for me. 45-minute video takes about 10 minutes to convert.
Hope it helps.
Aparna
i use ImTOO 3GP Video converter convert to mp4 then drag and dropt to walkman video folder good lick
