20 Most Recent
Singer CSP1 Iron Questions & Answers
My singer magic press 4 iron comes on but the plate will not heat
Not sure how tech savvy you are, but the service manual can be downloaded at http://www.parts.singerco.com/CPpartCharts/Presses/MP4.pdf
UNPLUG THE IRON. Figure 7 shows the wiring. Note that the lamp inside the switch is shown incorrectly. It should be on the other side of the switch. Also the 2 wires running down to the fuse are the red wires. The red wires are interchangeable. Use a continuity tester between wire 2 and wire 3 to test the thermostat. Should be open when dial is turned to the left. Closed when dial turned to the right. Also check continuity on the heaters. If everything looks good but it still doesn't work, replace the circuit board.
Steam press
Try sew4less.com--has tank & hose for about $16.00. I'm looking for a water tank cap for the same model if you have a source--Thanks
Transfering photos
hi there may i know if get any error on the unit..?be sure that there was an adequate heat on the machine,.
