20 Most Recent
Stihl HT101 Pole pruner Questions & Answers
Fuel lione and filter came off in the tank
This is a simple repair.
1. Drain tank save fuel can be used again
2.Purchase fuel line replacement kit Lowes -Home Depot
3.Kit needs to contain feed wire and gas hose.
4.Disassemble cover to reveal fuel line connection to carb.
5. Feed wire from kit into fuel tank through fuel line hole.
6. Install new hose over wire connecting end into hook at end of wire
7. Pull hose through tank up to the carburetor
8. Remove wire and connect filter and hose to carburetor
9. Replace gas into tank, Ck for leaks
Change gas filter in tank
hook out the fuel line and filter with a hooked rod, pull off the filter and push new one onto the pipe
Saw not firing
make sure that you left a 10 thou air gap between the armature leg and magnet.
Changing drive shaft
You should be able to just pull it out, it just slides into the clutc drum. It be stuck from rust, speay some WD-40 on it an let it set for a while, also try tapping on the clutch drum lightly with a hammer as you pull on the shaft. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/jason_a3dac712db4ca1a6
How do I set the timing
Are you trying to set the ignition or valve timing ? The ignition timing is factory set and changes with engine rpm - you can set the air gap between the flywheel and the ignition unit which should be around 0.25mm (0.010") Excessive air gap will retard the ignition timing. Unless you\'ve had the engine apart, the valve timing won\'t need re-setting. The valve clearances will need setting from time time and the clearance between valve and rocker is 0.1mm and is adjusted with both valves closed and piston at the top of it\'s stroke - you should replace the gasket and copper washer at the same time.
Stihl HT 101 Telescopic Drive Tube is rotating
Sounds like the baring block on the end of the extention section has come loose, they are held on by a rivet. remove the clamp by slackening it off and tapping the whole bracket off the main tube to expose it.
