20 Most Recent
Square Enix Kingdom Hearts II for PlayStation 2 Questions & Answers
Game freezes
Make sure that your system meets minimum requirement for playing it. Game may freeze due to less available hard disk, low capacity RAM and processor. So I would suggest you to follow these simple tips to avoid your games from freezing:-- Disinfect your system using some reliable antivirus program.- Upgrade hardware (RAM, CPU, graphics card, etc.)- Uninstall unnecessary programs (Games, crapware, toolbars, etc.)- Click Start> 'Run' Type msconfig > Enter > Start Up. Uncheck the boxes for the programs that you think you may not use often.- Clean all the junk files, registry errors and all the cache (Must use reliable program like I always use PCFresher for it.)Thank You :-)
How to fix a badly scratched up disk
Try peanut butter. After smearing it on the disk, wipe it off so that there is no peanut butter left. Make sure that there is none that is left to be seen. Then try to play the disk again.
Game stuck after gummi ship!
Is your disc scratched or dirty?
If so, the game could be hanging because
it can't load the results screen.
If that seems to be the problem, I'd suggest getting the disc resurfaced at a video store or games store.
I recently bought a Kingdom
What is probably happening is that the disk is either too scratched or too dirty to be read by the PS2's optical drive. Try cleaning the disk with a disc cleaning kit or by simply rubbing in with a microfiber cloth or 100% cotton shirt. If that fails to make it clean enough to be read, then you will have to get another, cleaner copy of Kingdom Hearts 2.
What are the code to the kh 2 ps2
www.gamefaqs.com
This is a site for troubleshooting electronics and whatnot, not a site for video game cheats. Go to gamefaqs if you want cheats, or just look it up in google.
Kindom Hearts II Freezing
Possibly the disk, you need to clean it with disk cleaner.
If the trouble still persist, it's the lens problem.
Open the case, then the mechanical case, after you see the lens, use a soft cotton buds, then put it in alcohol, then rub the lens firmly.
After that rub again with cotton buds without the alcohol, that should fix the problem.
Cant save on kingdom hearts 2
yeah, the game format does not support the 64 mb card (Its weird like that) I had the same problem, until I went out and bought an 8 mb card. Hope I helped
Help
That happened to me as well. I basically had to keep playing the game through without stopping.. which isn't hard. its an easy game. also, try having multiple saves. that often times works. like save in 3 slots each time you save. I also had to do this back with FF9.
Memory blocks
If i am thinking right??? kingdom hearts takes up about a third of the memory card to save. If you have 2 memory cards that are almost full but you can transfer a couple of games that you can transfer and fill one up then you should be able to get atleast 1/3 empty on the other. If you dont have two then ask a buddy to lend you the space for a couple of minutes and then try it. But dont do the same games that he has already on there because some games copy and replace old files. In other words you will save your game over his and he will loose his. If that dont work then it is most likely the memory card and there is not to much you can do without getting another.
When requested to install told that not enough
It may need additional temporary space. Now you say youhave 32 GB and it requires 39 GB. That's 39 GB- 4 GB= 35leaving a 3 GB play room. Too close for comfort. Eliminatethose videos of the dog and cat playing, and you'll have tonsof space.
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
